Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Condensor running, some cool air on both sides, not cool enough
Freezer stopped freezing, we've vacuumed the condensor coils, and are waiting for results. Cool air is blowing, just not enough for food/ice
  • 410 Answers
There are 2 things I an think of right off. the most likely is a defrost problem. Look at the back wall of you freezer compartment and look for snowy ice build up if so most likely culprit would be defrost termination switch. the switch is inexpensive and easy to replace. you will need to order it by your model and serial number.
the next not as likely problem would be a low freon charge this problem would require a good service company to repair for you.
Good luck peyton
Posted on Jan 20, 2009
Freezer will not freeze water in bottles and seals between freezer door and fridge are very hot to touch
That means that heat from the compressor is being transferred to the rest of thet machine like a heatsink. The reason why is either the condensor fan motor is not running which most likely the reason, or the condensor coils are severely dirty. You'll need to pull the machine out from the wall, leaving it plugged in and remove the lower plate at the bottom. Locate the fan, usually more toward the right hand side if your behind it, and if the compressor is runnning then the fan should be running. Period. The fan draws air across the compressor and blows it throught the condensor coils which will located right next to the fan, cooling them down.
May 08, 2012 | Hotpoint Refrigerators
Jenn-Air JCD2389GES problems
The condensor fan cools the condensor coils. If it is running this will cause a no cool situation. Also, if the condensor coils are plugged with dirt that insulates the coils and causes a no cool situation. These things will make it so the freezer isn't cold enough to freeze water so the icemaker will not produce ice. As far as the door edges getting hot. A condensor line runs thru the cabinet between the doors and this is called the mullion. If it is too hot this is a good indication of a bad condensor motor or dirty coils. Clean the coils and check the status of the fan motor and let me know what you find and we will see if we need to go further.
Nov 11, 2007 | Jenn-Air JCD2389G Side by Side...
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
May 04, 2011 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
I REPLACED THE DEFROST ASSY COMPONENT ON MY JENN-AIR REFRIG, BUT STILL WON'T COOL ENOUGH. fREEZER WON'T FREEZE side by side jcd2289
Make sure both fans are running and check that your the coil is not frozen. The coil is behind the freezer panel.
Jul 02, 2009 | Refrigerators
RS20EKXEW00 FREEZER NOT FREEZING AT ALL AND REFRIGERATOR SIDE NOT COOLING WHAT IS THE PROBLEM? COULD IT BE THE CONDENSOR?
1. is the compressor running? if so is it hot to the touch? is the condensor fan running? coils dirty? let me know ... mark whirlpoolpartssurplus dot com
Jun 10, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
No water no ice
Dear Customer
Please perform the following checks
Refrigerator starts and stops frequently :
Refrigerator or freezer is not cold enough :
Please rate this,Thank u
Dec 18, 2008 | GE GSS20IEP Side by Side Refrigerator
Freezer on the ge refrig will not freeze
Dear Brendadurran,
please rate this solution if it meets ur need,else choose fixya.
please perform the following checks,
  • Check the temperature setting
  • Clean the condensor coils
  • Unplug the freezer, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • hope this would help,please rate this solution if it meets ur needs,else choose fixya.Thank you.
    Dec 17, 2008 | GE Profile PSS26NGS Side by Side...
    Refrigerator cools, but no freezer fan & no condensor fan running
    Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
    Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
    Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
    82 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De GO PATS
    Jim Goldsmith
    Jim Goldsmith
    Arnel
    Arnel
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
