I have the breville Aqua Fountain AF5 and the red light indicator will not turn on. Can you help as to why the red light will not illuminate.
  • Dale Koehn
    Dale Koehn May 11, 2010
    does it still operate ?
    Novelist:
  • 88 Answers
Have you changed the filter ? if its still operating, and you have changed the filter, the (LED) might be burned out, if its a new unit, then take it back where you purchased it and have them replace it, if its an older unit and it still works, then you might have to live with no (LED) , hope that helped
Posted on Jan 20, 2009
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Where could i get an instruction manual for a BJE400 Breville Juice fountain
https://www.breville.com.au/media/mediaappearance/2737/BJE410.pdf
Aug 18, 2016 | Breville Juicers
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Where do I buy a replacement gasket for breville fountain elite juicer?
However reliable and durable your Juicer is, at one point in time it will need Replacement of parts. It is Great to buy a model from an established brand like Breville, where Juicer parts or accessories for these juicer machines are easily available.
Jan 08, 2010 | Breville 800JEXL Juicer
Breville JE90J juice fountain spare part
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06 DRIVE COUPLING,
JE95/26 FILTER BASKET & DRIVE COUPLING
If you email me at sales@ewingelectrical.com.au I can help you with prices etc.
Mar 28, 2009 | Breville JE3 Juicer
Can't find a replacement filter
Try Brita or Aqua Optima filters
Aug 21, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
207 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
