Question about Air Tools & Compressors
Why does air tool blow air without driving
Good air pressure but triggering tool simply bypasses air without driver action
    New Friend:
  • 27 Answers
Either you have lubricated the head instead of the air inlet end or you have worn out the little ball bearings in the head. The drive head only needs a dap of light grease bi annually or when being repaired. The air inlet end needs oil drops daily or every time you use it. Once the two little ball bearings in the head have flat spotted they are worn out and need replaced.
Posted on Feb 18, 2013
Will not fire a nail when triggered.air passes through and out of trigger. seals checked ok. driver checked ok
pound out the trigger rocker switch and see if its that. press the trigger valve button without the trigger in place. could be your trip is not engaging the trigger far enough to make sufficient pressure to push the trigger down .
Nov 09, 2015 | Porter Cable DA250C 15Ga 212" Angle Finish...
Engine is running faster than normal & causing spray to come the wand without pulling trigger?
Trigger for wand needs replacing, water bypassing it and not allowing pressure build up enough to close pressure switch, allowing engine to go back in idle
Sep 16, 2015 | Garden
Pressure washer pump not pressuring
Some of these pumps have a pressure bypass valve when you release the trigger on the gun it won't blow the hose ( safety feature) I could be that the vale is stuck
May 26, 2014 | Karcher 2500 PSI Pressure Washer
Pneumatic stapler trigger stuck
The click sound indicates that the headvalve opened to fire piston down the barrel, however piston is already down or is stuck in-place. If the piston/driver is not broken or stuck, push piston to top of cylinder to reset. If only one shot and piston stays down, most likely the check band is broken. Check band is on the outside of cylinder (lower part) is is usually an oring or band of rubber covering small holes drilled into cylinder. Check valve /band is what causes the piston to return to top. If check band is good, most likely piston is bent or oring is too tight. If you open the gun, lube all parts with white grease or silicone paste lube. Good luck
Nov 03, 2012 | Air Tools & Compressors
Air leaking around trigger valve. Air blowing out of green valve center pin gets push in in nounal working condition but now air blows out continue when hooked to air pressure
there is an oring that has split on the trigger valve and you would need to replace the valve assembly. Without knowing which tool you have I can't give you a part number but if you look in the tip section I have detailed instructions on how to remove and replace this valve. If you give me the model I will try and find you a source and part number for your nailer. Let me know if I can be of more help or if you have trouble finding the instructions.
Jul 04, 2011 | Stanley Bostitch Nail Gun
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at www.toolpartsdirect.com. Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
No air on tools side
Hi, Between the two gauges is the regulator adjusting knob. Turn this until you see the pressure rise on the tool side gauge. You can also test for a rise in pressure in the air hose by connecting a blow gun, and pressing the trigger as you make adjustments. If you cannot raise the pressure with the regulator, it is probably bad.
Best regards, --W/D--
Mar 05, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a Bostitch SB-150SX pneumatic stapler. It's about 5 yrs old. I've been using it for the last couple of days without any trouble. Then yesterday, it would not shoot. When I pull the trigger air...
Are you using air-tool oil before each use? Water or debris coming through the air hose can cause like problems. Try installing an in-line filter. Hope this helps!
Aug 13, 2010 | Garden
No air pressure at the hose
It sounds like you have trouble with your pressure regulator. Make sure that the knob for the regulator is turned clockwise to increase pressure. If this doesn't work, you may need to replace the regulator.
May 24, 2009 | Hitachi EC12 Portable Electric 2hp Air...
The motor is pulsing on and off without the trigger being pressed
It is probably sucking air on one of the connections or around one of the fittings at the regulator. You can also turn the pressure up allittle on the regulator, that might stop it also. Make sure the clamps on the hoses going to the regulator is tite. Also it could be that the regulator is just bypassing water and if it has air in it it will pulsate.
Mar 14, 2009 | Karcher K2.26 Electric Power Washer
Air Tools & Compressors Logo
673 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
