Question about Exercise & Fitness
Nautilus treadmill- I can go up on speed but not back down
Nautilus 800.6 Treadmill
    Top Expert:
  • 12,223 Answers
Please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well, see the diagram.
Happy New Year. God bless you
Nautilus treadmill- I can go up on speed but not b - 1_2_2013_1_29_30_am.gif1_2_2013_1_29_49_am.gif
Posted on Jan 02, 2013
4 Suggested Answers
  • 11 Answers
SOURCE: Treadmill belt adjustment
There are two bolts on the back of the treadmill. Turn the right side clockwise to make the belt go left, turn the left side clockwise to make it go right. Never tighten more than 1/2 turn at a time, and do this while machine runs at 2-3 mph. Belt should be just tight enough to not slip. If your belt is really tight and it still slips you have other problems.
Posted on Feb 09, 2011
ercupa190
  • 12223 Answers
SOURCE: speed is off on nautilus exp 1000x treadmill
Please use your calibration software for recalibration your fitness according with your owner manual. See the instruction too below the hood. and proceed for fix it.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Posted on Dec 19, 2011
ercupa190
  • 12223 Answers
SOURCE: Cybex 530t treadmill speed slows down intermittently anyone help
Please LUBE deck belt + rollers bearing too
2) test the input voltage motor, if there are the motor need repair.
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Posted on Dec 17, 2012
Can I find service in Europe
Customer Care Number: +1-800-628-8458, +1-800-605-3369
See More Detail Email Address: csnls@nautilus.com
Contact Person:
Address: 17750 Southeast 6th Way Vancouver, Washington 98683, United States
Website: www.nautilusinc.com
Contact Nautilus Inc
Nov 02, 2015 | Nautilus T914 Commercial Series Treadmill
Startrak 950 orbit treadmill
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Jun 03, 2013 | Nautilus Exercise & Fitness
Calibrate nautilus T914
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Nautilus T914 Commercial Series Treadmill
Nautilus NTR 800.6 Treadmill. I can go up on speed and incline but not back down?
please RUN the software calibration, for easy diagnose, troubleshooting, and fix it.
Test the speed sensor, for open or faulty, clean it, and tight the connector very well. see the diagram
Jan 01, 2013 | Exercise & Fitness
I have a Precor 9.33i Treadmill. It works perfectly until I start to walk/run on it and then it shuts down. What is causing this?
LUBE THE deck belt, this happen because the system protect the electronic system, with shut down.
2= LUBE THE ROLLERS BEARINGS TOO
3= measure the input voltage motor, if there are the motor need repair
4= measure the output voltage board, for input voltage motor, if there are NOT the boar is faulty.
see the block d
God bless you
Jul 19, 2012 | Nautilus Ntr 800 Treadmill Lift Motor
Nautilus t514 safe key issue
1_ reset the machine, disconnect the machine.
2) test the magnet, the key is magnet, test for attraction or repulsion with the magnet from your refrigerator, if do not pass the test replace the magnet.
3) replace and go and buy in homedepot for little price!
God bless you
Jul 18, 2012 | Nautilus T514 Treadmill
Speed is off on nautilus exp 1000x treadmill
ernesto cuadra
Dec 10, 2011 | Exercise & Fitness
Jan 03, 2010 | Nautilus Exercise & Fitness
Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Aug 29, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
