Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Westinghouse WSE6070SA - My filter needed replacing so I bought a new filter from a local retailer. It is a genuine Electrolux part. Since replacing this filter I have had problems with the ice-maker in that it is not producing ice. Also the filter is very loose and keeps falling out of the housing. I wonder if the retailer has given me the wrong filter. The number on the filter box is 240396407K - WSE6070WA
5 Suggested Answers
  • 557 Answers
SOURCE: WATER FILTER connection is leaking even after
make sure the old seal from the old filter didnt stay on
Posted on Oct 29, 2010
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
SOURCE: Has anyone out there had
yes. Motherboard replaced 3X icemaker 2X other parts 5X
Posted on Feb 10, 2011
imufo2
  • 3773 Answers
SOURCE: I have a Frigidaire Electrolux
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 20, 2011
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
Can't find the belt # for an electrolux genesis upright, serial number u 75344 p
The best place to get a genuine belt is the local Aerus Electrolux store. They're the only place to get a genuine belt without going on line. Most of their uprights use the same belt, so the store should have it on hand. I do highly recommend allowing their technician to make the switch as the power nozzle can be a bit tricky taking apart and reassembling.
To find the store nearest you, follow the instructions on the following site.
http://www.aerushome.com/storelocator/
Nov 26, 2010 | Electrolux Vacuums
Need a new electrolux power nozzle model N106m
If you're looking for a new head for your vacuum. Then you're going to have to replace it with the same type of nozzle.
However, wall inlets are standard so you can purchase any kind of attachment kit and it'll fit your inlets and work with your system. Their are many online retailers that offer a wide range of kits that will fit your system.
Mar 22, 2010 | Electrolux Centralux Vacuum
Where can I gett a replacement filter collar for Electrolux Harmony , model EL6985?
HI. I can assist you. Any electrolux dealer can get the part you need. To locate a local dealer go to this link:
http://smallappliances.electroluxusa.com/node85.asp
Aug 01, 2009 | Electrolux Harmony Canister Vacuum -...
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Frigidaire electric range fef326ab bought in oct 2005 heating element sparked while baking and now there is a hole in element, what could have caused this and could it be fixed, or will i have to buy new...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573215
Generic problem for all Kitchen Ranges
Posted by keepcooking on May 05, 2008
Frigidaire electric range fef326ab bought in Oct 2005
heating element sparked while baking and now there is a hole in element, what could have caused this and could it be fixed, or will i have to buy new range?
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
To the best of my knowledge you can replace the heating element with a genuine part from Frigidaire, this happened to me on my water heater and the element just got old and too hot and it just popped and left one to three holes in the element and I just replaced it. I would have it done by an appliance specialist or your local appliance repair person. When ordering the part remember to give the Brand name, Model # and they might ask for the Serial #. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.frigidaire.com/products/products.asp
Contact Us
Customer Contact Center - USA
1-(800) 374-4432 Monday thru Friday 9:00 am to 5:30 pm EST
Canada 1-(800) 265-8352 Monday thru Friday 9:00 am to 5:30 pm EST
Extended Service Agreements 1-(866) 386-5286 Monday thru Friday
8:00 am to 6:00 pm EST
Order Genuine Frigidaire Parts 1-(800) 599-7569
8:30 am to 5:30 pm EST
Mailing address:
Electrolux Home products
P.O. Box 212378
Martinez, GA 309
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
118 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
