Question about Maytag Neptune Washer
Mah9700 gets stuck at 8 min unless we run a very small load
If the load is more than a few pieces the washer will continue repeating the cycle at 8 min/ Sometimes it will finally count down to zero; but usually we must take the clothes out when still wet.
  • Elizabeth Galusha Jan 03, 2013
    We showed this answer to our appliance repair technician, but he feels the problem is too difficult to fix, and we don't have the expertise to fix it ourselves. So far, I don't know if your solution is helpful because I still have to find someone to follow through with the suggestion. Thank you.
  • Maytag Master
  • 17,130 Answers
It is possible that when the load is more the drive pulley slips and does not get to the set RPM. This can be due to many reasons and so it can be related to no drain of water and thus making the timer to count down. Check the drive by removing the bottom plate, roll it with your hands to check for friction.
Posted on Jan 01, 2013
  • 298 Answers
SOURCE: Washer will not spin; displays nd error
(nd) stands for no drain check the pump,and drain hose
for clogs
Posted on Dec 24, 2007
IB4G2008
  • 3587 Answers
SOURCE: Mildew/Stagnant water smell in washer
you know, this does happen.
run it on a full cycle, warm, with either of these in solution.
baking soda, at 1/10 concentration
non chlorine bleach, at 1/6 concentration
you most likely need to do this more than once, until your nose is happy.
Also, consider doing this at least once every 200 wash cycles.
essential oils have same effect, and do a nice anti microbial as well.
we did this in commercial laundries all the time, as part of standard health code compliance issues.
Posted on Feb 18, 2008
  • 3 Answers
SOURCE: ERROR CODE E3
Here is what it says in Maytag's Technical Info Guide: Machine control is
attempting to drive the
motor but is not seeing any
tach response. Visual
check shows motor is not
moving. (Locked, Hall
Sensor fault)
Here is the web site for the guide:
http://www.servicematters.com/maytag_library/docs/16026736.pdf
Try this: take off the back panel and check the motor connections. Unplug them and look for any corrsion.
Hope this helps.
Posted on Jun 16, 2008
SOURCE: MAYTAG MAH5500BWW Fails to spin properly clothes wet
I replaced the motor and circuit board but that did not fix it. I changed the out of balance switch and the shock absorbers or snubbers. I think the ultamate fix was the snubbers. it has worked great since. They wear out like your car shock absorbers allowing the drum to shake too much triggering the out of balance switch to stop and restart the spin.
Posted on Jan 24, 2009
SOURCE: maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Posted on Apr 18, 2010
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
Stops mid-cycle, does not drain, displays nd error code?
Hello.
That code is telling you that the unit is draining to slow. After 15 minutes it is not below the low water level and will not spin out. The best repair for this is to replaced the pump on your unit.
Jul 15, 2009 | Maytag Neptune MAH9700 Front Load Washer
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Mar 02, 2009 | Maytag Neptune MAH9700 Front Load Washer
Washer problems.
some of those pumps had a small hose going to it from the water level control have had trash pulg them up on pump end and at pump port ck it ..if pluged control may thing washer has enough water and will not let any in also pump may have gone kaflooey
Sep 16, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
LG WD-8074fhb
Your problem is either in the control board or the water level switch.  The computer can't tell if the water has drained or the control board is stuck in the 8 minute drain cycle.  Recommend pulling the plug and wait 5 minutes to reset the computer.  If the problem persists, it will require an LG experienced tech to see what's going on.
Mar 14, 2008 | LG WM1814CW Front Load Washer
ERROR CODE E3
Sensor fault)
Hope this helps.
Mar 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
