Question about Sewing Machines
Kenmore 385 1960180 won't pick up bobbin thread
SOURCE: bobbin thread will not pick up nor will dog feed rise
my Brother sewing machine model VX 1120 will not pick up the Bobbin Thread. Machine is fairly new with only several hours use. I have changed needles , tried different bobbins, cleaned the machine. Any suggestions?
Posted on Jul 13, 2008
SOURCE: The machine won pick up the bobbin thread, it jams when starting
wont pick up thread from bobbin
Posted on Nov 28, 2009
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
  • 415 Answers
SOURCE: All of a sudden the needle won't pick up the
Check the tension. Make sure the bobbin tension isn't too tight and/or that the top tension isn't too loose. If the bobbin tension is too tight it won't be able to be drawn up and make the stitch. If the top tension isn't tight enough it also won't be able to draw the thread up. They need to be balanced to work together.
Test the bobbin tension by dangling the bobbin (in the casing) by the thread and give a slight flick of your wrist. It should drop down a bit as the thread is released. If it hits the floor it is too loose btw. If it doesn't drop a bit without great yanking it is too tight.
Then check your top tension and make sure there's a bit of resistance when you pull on the thread.
If you're having a lot of problems first try sewing on a plain cotton material and examine the stitch when set to a wide zig zag. When you get it adjusted so it sews that correctly then go back to what you were sewing on and make sure you have the right size and type of needle and that it is inserted correctly.
One of those things should correct the problem.
Posted on Jun 11, 2011
SOURCE: i have a singer stylist model 413 that the bobbin
I have the same problem! Did you ever figure it out?
Posted on Jul 31, 2011
My kenmore sewing machine model 11607090 won't pickup the bobbin thread
try changing the needle
try rethreading the machine top & make sure to use
every thread guide
make sure the bobbin is turned the right way in the bobbin case
it's also possible that the machine may need to be checked to see
if there is a timing problem
Oct 15, 2012 | Kenmore 11206 / 11306 / 11506 / 11606
My kenmore sewing machine won't pickup the bobbin thread
if you've tried changing the needle & tryed rethreading the machine
then it's possible that the machine need to have the timing checked
JUKI BOBBIN THREAD WILL NOT FEED
Most machines require that the bobbin in the case unspool in a certain direction its considered common knowledge I guess because it doesn't seem to be written in the text of manuals... but is indicated in the photos. make sure it's unspooling correctly.
Secondly. Please make sure you have the correct needle for your machine. Some machines do not use a 15x1 (most common needle) Let me show you. (see photo below) Clearly the 241x1 won't fit into your machine. BUT the 15x1 will go into the machine that requires the 20x1.... and the result is it won't pick up the bobbin thread.
Start there. Then check your timing.
Sep 05, 2012 | Sewing Machines
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
LS-1520 Brother sewing machine hook pick thread up takes it around half way and gets stuck...any ideas. the timing seems to be right??!!
try changing needles
clean under the needle plate & in the bobbin area for loose thread or lint
make sure the bobbin is inserted into the bobbin case correctly--if the
machine won't pick the thread up from the bobbin correctly take the bobbin
out of the case & turn it around & try it that way.
Apr 13, 2012 | Brother LS-1520 Mechanical Sewing Machine
Needle won't pick up bobbin thread
check to make sure that the needle was put into the needle holder correctly
all the way up into the needle holder--flat side of the needle to the back side of the machine
if the machine still doesn't up the bobbin thread then
it's possible that when the needle broke that it caused the machine to go out of time which means it has to be retime at a sewing machine shop
Feb 28, 2012 | Sewing Machines
Thread on sewing machine won't pick up bobbin thread
the bobbin case does not move, just the bobbin.. if the machine is still under warrenty, I would take it back & get another sewing machine,, and probably not from them
Feb 26, 2012 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
