Question about Samsung Star II Cell Phone
Where to put my APN settings when the fields dont match up with the fields for APN on unlocked GSM phone
  • Samsung Master
  • 14,641 Answers
Hapy New Year:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Posted on Jan 01, 2013
3 Suggested Answers
SOURCE: Problems with Samsung E590 sim Unlocked GSM Phone?
need puk for sgh-e590
Posted on Apr 04, 2009
SOURCE: how to add apn for sgh a597 on straight talk
AT&T phone on Straight Talk (sprint)? Unfortunately, AT&T uses GSM which is not compatible withSprint's CDMA technology.
Straight talk runs on the Sprint network, same as Boost and Tracphone. Although some phones are the same, some only work on certain networks.
Posted on Sep 05, 2012
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
Oct 16, 2015 | SVP G13 Gsm Unlocked Watch Cell Phone...
Setting apn
Open the main menu and touch "Tools & Settings". Touch "More" and select "Connection". Select "Access Points" and touch "Add profile". Type the settings for the connection. Enter a name for the connection in the "Connection Name" field. Verify the Bearer field is set to "GPRS." Set the "Authentication" setting to the type specified by your carrier. Type the username and password in the specified fields. Enter the access point name in the APN field. Touch "Save" to confirm.
Mar 12, 2014 | LG Encore Gt550 Unlocked At&t Touch Screen...
Flash to straight talk
I believe straight talk uses CDMA and GSM devices. For GSM devices it is a matter of putting the sim card in the phone (if it is an unlocked phone) and adding the APN settings, under Settings/Mobile Networks. Please go to http://www.straighttalk.com/wps/portal/home/support/apn to get the settings for your phone.
If it is CMDA, I would take it to a local cell phone flasher. It would require more information than APN setting to make it work properly. Most CDMA flashes are done with CDMA Workshop or DFS.
Dec 15, 2013 | Cell Phones
How can I set up 3g in xperia go?? I can't download internet and MMS settings. thanks
you have to set it up manually. get info from your service provider, check if their 3g band matches your phone 3g band. if they dont match you will be on 2g/edge speed. google out internet and mms settings for your service provider. after you get that info go to settings-->wireless&networks-->mobile networks-->access point names-->option-new apn-->type in the info in the appropriate field-->save and you should be good to go.
Sep 24, 2012 | Sony Xperia go ST27i White Water proof...
Sir i have mmx610u usb and i unlock it. now iwant to use as a 3g modem , how
Hi ..
If you successfully unlocked the data card, then you will able to use any network's SIM Cards.
All you have to do is to edit the configuration file so as to make following changes:
1. Change APN - Change old operator's APN (Access Point Name) to Current Operator's APN.
2. Change User Name - In USB Modems, username usually means that current mobile phone number of SIM(eg.: 0425483456836). Many operators dont need this field and left empty.
3. Change Password - Like username, its bunch of numbers for security. Like username, many operators don't need this field either.
4. Change Homepage - This field is not that much important, yet just matter of our preference. Specify first page to be loaded when a connection is established. (ex.: www.google.com)
you can easy get these informations by placing this SIM on your mobile phone and ask your operator to tell its configurations. Or if your phone already has data account, then you can get these infos from that. Just select edit option and note down all shown settings on a paper.
Mar 13, 2011 | Computers & Internet
How do i get my gprs working
AT&T:
Main Menu
* Entertainment
* Services
* Data Account
* GPRS
- Find one free account (like Account 8, etc)
* Edit
- Change 'Account Name' and put the value 'ATT MMS'
- In 'apn' field put the value APN (which is wap.cingular)
- Fill the fields username and password with the ones on the table USER and PASSWORD (you don't actually need a user name and password for AT&T, you can leave these blank)
-Click 'Done' and say Yes to Save.
* Main Menu
* PIM
* Messages
* MMS
* Message Settings
* Server Profile
- Find one free account (like Profile 8, etc)
* Edit Profile
- Rename Profile and put the value 'ATT MMS'
- In Homepage field put the value HOMEPAGE (which is http://mmsc.cingular.com)
- In 'Data Account' select GPRS and then the account created before (the MMS one).
- Select 'Connection Type', choose HTTP and click OK
- Fill in the fields Proxy Address with PROXY and Proxy Port with PORT. Then click OK (066.209.011.061 is the proxy and 9201 is the port number)
- Fill the fields username and password with the ones on the table USER and PASSWORD (don't need a user name and password)
* Go back and Activate Profile
Nov 16, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Samsung Star II Cell Phone Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
