Question about Compaq Computers & Internet
My compaq pressario power is turning on but pcu is not starting up
It has windows vista home basic and it is making a noise where it will make a long beep twice and stop for about four or five seconds and then there will be one and stop again for about six to seven seconds and the cycle repeats and i will look to see if the processor light is on and it will light up for a split second when i turn the computer on and it wont light up any more
  • Compaq Master
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Remove added memory If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory If you have access to another computer that uses the same memory, try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced. Replace memory If it is determined the memory in the computer is bad we suggest that you replace it if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible b> Hope this helps.
Posted on Jan 01, 2013
  • 3 more comments
  • Keith Hertel Jan 02, 2013
    I did that and now it is doing a one to two second beep and then there is a two to three second pause and then there is a three second beep
  • Brian Sullivan
    Brian Sullivan Jan 02, 2013
    so what are they 3 long beeps or 2 short one long check the video (graphics card ) even remove it clean the socket check the power and data leads replace it resart your computer the found new hardware wizard should activate make the keyboard usb or ps2 lead are properly seated
    its a short and then a long beep
  • Brian Sullivan
    Brian Sullivan Jan 03, 2013
    single short beep and single long beep code for memory problems
  • Brian Sullivan
    might be a faulty ram module www.memtest.org To test RAM check here - let it run 4+ hours or so. <-- best method or faulty memory slot http://www.youtube.com/watch?v=wGp5AiyJI...
davecon
  • 85 Answers
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
Posted on Apr 22, 2008
leecom72
  • 4806 Answers
SOURCE: hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Posted on Dec 14, 2008
Bay Ridge
  • 102 Answers
SOURCE: Beeping emachine desktop won't turn on
Hi shyguy,
Before I address your issue, I figured you ought to know:
Buying an emachine is one of the worst moves a consumer can make. Why? because despite the fact that they are cheap, they frequently have problems, which can take money out of your pocket. Not only that, but they can be a pain in the *** in general. The old saying "You get what you pay for" should certainly be followed to some degree when purchasing a computer.
Now that I got that out of the way, on to your problem. I have a feeling that your motherboard might be shot. Before I have you think that, I want you to see if you can open it up and check to make sure your RAM is seated in the slot properly. If that doesn't work, then I think your motherboard is most likely gone.
If you need any more assistance, I'd be glad to try and lend a hand. You can e-mail me at perdue1202@yahoo.com
Good Luck.
Posted on Sep 16, 2009
guitarman002
  • 80 Answers
SOURCE: computer wont start and i get a series of four
4 beeps mean your th'ers something wrong with your computer's memory. Make sure that the chips are seated firmly in their sockets If that dont help pull out the chips and reseat the chips
Hope this helps.
Posted on Sep 28, 2009
  • 28 Answers
SOURCE: Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Posted on Nov 19, 2009
How do i reinstall vista home basic on my compaq cq60 notebook
you have to put the vista home basic disk in the dvd drive & follow the prompts
Mar 31, 2012 | Microsoft Windows Vista Home Basic Edition
My compaq pressario wont start up windows vista, it only appears a black screen with different commands
That is the boot option screen - if you can't get past it then Windows is totally corrupted and the only thing you can do is to reinstall it.
Nov 05, 2010 | Computers & Internet
I cannot install ethernet driver of hp compaq d530. Where can i find it?
Hello: I hope the following information is helpful.
If you are trying to install the driver for the Broadcom ethernet NIC that was pre-installed (NOT an ethernet card that you purchased and installed yourself), there is a softpack (updated driver installation) download available from HP/Compaq. It will install the driver automatically for you, just download it from the link below and run the ".exe" file.
IMPORTANT: Check to be sure that your current Operating System, and model of the network device you are trying to install, are BOTH listed below BEFORE you download!
This is a software / driver update for the HP Compaq d530 ultra-slim desktop: All Models
Supported network devices:
BCM5906M Broadcom 10/100/1000 5782 based NIC Broadcom 570x 10/100 Integrated controller Broadcom NetXtreme Gigabit Ethernet 5782 Broadcom NetXtreme Gigabit Ethernet PCI-Express NetXtreme(tm) 10/100/1000 Gb NIC
Supported Operating Systems: Microsoft Windows 2000 Microsoft Windows 98 Microsoft Windows NT 4.0 Microsoft Windows Vista Business 32 Edition Microsoft Windows Vista Business 64 Edition Microsoft Windows Vista Enterprise 32 Edition Microsoft Windows Vista Enterprise 64 Edition Microsoft Windows Vista Home Basic 32 Edition Microsoft Windows Vista Home Basic 64 Edition Microsoft Windows Vista Home Premium 32 Edition Microsoft Windows Vista Home Premium 64 Edition Microsoft Windows Vista Starter 32 Edition Microsoft Windows Vista Ultimate 32 Edition Microsoft Windows Vista Ultimate 64 Edition Microsoft Windows XP Home Edition Microsoft Windows XP Professional Microsoft Windows XP Professional x64 EditionINSTALLATION INSTRUCTIONS: 1. Download the file by clicking the "Download" or "Obtain Software" button and saving the file to a folder on your hard drive (make a note of the folder where the downloaded file is saved). 2. Double-click the downloaded file and follow the on-screen instructions.LINK where file can be downloaded:HP/Compaq Support-Broadcom Driver download
Again, I hope this information is what you neededto install your network device. Should this not answer your question, please come back, provide more details of your problem, and we will be happy to help!Best of luck to you!
Jun 23, 2010 | HP Compaq d530 Ultra Slim PC Desktop
In my compaq Presario cq40 notebook with vista home basic. I wish to upgrade my os with vista prenium or ultima. Where shuld i contact?
Genuine Windows Vista Home Basic 32-bit is supported on this laptop.
If you want to upgrade its at your own risk.
Aug 30, 2009 | Compaq 40/80 DLT VS (td-cq40225) Tape...
Sub woffer unable to play
is it a active sub make shure that your small jack is stereo
Mar 30, 2009 | Compaq Presario 700 470024-192 Notebook
I have compaq 3000 series model is 3702tu. the problem is windows is not getting started. i have vista home basic
Hello! May I suggest getting Windows to sort the problem for you? power up the P.c. and insert your Windows Basic disc, then shut down. (With disc in drive) Boot (Power up) You will be prompted to start/run from cd by pressing any key? do this and Windows will load all files then prompts you again for locationj and keyboard settings, after this it will if you want to upgrade? full install? REPAIR! click on repair and Bingo hopefully you are back on the case.
Good Luck! let me know how it went?
Paul 'W'
Onyer~EDson(:0)~[><
Dec 10, 2008 | Compaq Presario Notebook
MISSING FILES OF WINDOWS VISTA HOME PREMIUM
You can boot up your Vista cd and it will give you the option to Install or Perform a Repair.
Since you say that you have already re-installed it, I would save the data and continue with a complete installation IE:format and Install.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | Compaq Presario 700 470024-192 Notebook
How to install turbo c in vista home basic compaq pressario lapto??
how to run turbo c in full screen mode on vista operating system.
when i am running turbo c it's gives  a message that vista not support full screen. what should i do please suggest me.
Sep 13, 2008 | Compaq Presario Notebook
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
