Question about Universal Remote Control Omega MX-650 LCD Remote Control
Where do I send in for repair
RF circuit board detached from main board
Will not charge the port in the kindle fire broke
Hello!
We repair these A LOT! The jack is unbalanced on the Main Board and is easily detached by normal wear and tear. Soldering the jack back on to the board is a little tricky but the real repair is getting the port sturdy to prevent the issue from re-occurring.
We do a full repair by removing the old solder on the board and the jack then reattach using flux and fresh solder. We also stabilize the port so it doesn't happen again.
You can send it from anywhere in the US and we'll repair it for $39.95 which includes return shipping. I strongly recommend replacing the micro usb / charging port for an additional 9.95
www rockhoptec com
please call or email with any questions!
(585) 487-8220
alex @ rockhoptec com
Jan 05, 2014 | Amazon Computers & Internet
Garmin not receiving satellites
hmmm...did you check for the latest firmware, by chance?
Feb 29, 2008 | Garmin StreetPilot 7200 GPS Receiver
I have a Behringer PMP5000, after a gig, I accidentlly plugged the outputs from an external power amp, into the monitor sends and powered up the unit. After I realized what I did, I powered down, corrected...
Yes, you blew out components associated with the monitor sends. There are several components including an RF bypass to ground and the driver IC, IC8 and a decoupling electrolytic cap. The repair is going to be extensive as it is likely you will have to remove ALL the panel knobs and screws to free up the circuit board for repair. I have worked on several mixers and have three of the PMP5000's myself and dread removing the main board. I am going to suggest something you might consider: Many of the PMP's fail either in their power supply or one of the amps. Due to the repair cost I would consider getting a scrap PMP with this problem and swapping out the panelboard for yours. Often you can get one with blown supply or power amp for around $200 and I suspect a repair shop is going to charge at least that to repair your unit... Then you will have a spare parts bucket as well.
Oct 07, 2011 | Behringer Europower Pmp5000 Powered Mixer...
RF connector broke from board....looks like part number is 1519592K, but nothing appears when I enter that part number..how do I get new board?
You can't buy the RF connector parts from a TV component supplier as they are already soldered to the main board. A friend who can solder PCBs or a TV repair shop should be able to re-solder the original for you. If it's damaged, a TV repair shop might also be able to find another that will fit as they are fairly standard components. This will be far cheaper than buying a new main board and it's probably going to be difficult to get one.
I had a look for a new main board, but the TV is fairly old and I couldn't find one or a part number. It's easier to find components by part number rather than by TV model, so your best bet is to find the part number on the main board and try searching for that on Google or similar.
If you want to post back with the model number, I don't mind having a search for a replacement main board, but my advice would be to get the existing repaired, if possible.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | RCA MM36110 36" TV
When I power up, it starts @ the "safe mode" screen then when I make a choice after a few seconds, it shuts down. My wife noticed last night it was hot to touch. I thought nothing of it until this...
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
As the fan is not moving,computer is running hot so it is shutting down.Need to check the fan cable, reset the cable,if it works it is fine,other wise need to replace the fan.
Disassembling the Lower Case Assembly
  • Disconnect the Bluetooth cable from the main board.
Sep 26, 2010 | Acer Aspire 5050-3242 Notebook
No more receive
This scanner uses SMT parts and a multi-level board. If RF from your Yeasu cooked it, you have no choice other than to send it in for repair. Unless you have access to SMT equipment and understand you can't repair traces on a circuit board with multiple levels, you are sunk. Send it in for repair. They will shotgun the board and get it back to you.
Apr 28, 2010 | Radio Shack Pro-2096 Base Scanner
GPS signal is weak or no signal
Bozena/Anton,
Thanks for using FIXYA!
Careful when opening the case because you'll have to unplug the cable from the main board prior to opening the case completely.
The RF cable could be loose inside. Carefully open the unit as to not potentially cause any further damage. The RF cable will be gray or black, it will be the only cable connected from the main (big) board to the RF (attached to the rear housing.. I believe) board. The connectors on either side of the cable have came loose. A "pad" being lifted results in a repair process that's beyond me, this meaning you can see white as opposed to silver. It may help continuity to re-flow the solder, if everything looks fine (heating up the existing solder and adding fresh solder).
Unplug the cable on both ends and plug back in to make sure the connectors on the circuit board aren't coming loose. If soldering is out of your league then I suggest finding someone that can. Let me know what happens, and careful when opening the case because you'll have to unplug the cable from the main board prior to opening the case completely.
Oct 26, 2008 | Magellan RoadMate 700 GPS Receiver
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Need cable connection circuit board for symphonic wf2702 television
I replace just the rf connector. You should be able to pick one up at you local repair center. If you did not damage the tuner which the jack will get solder'd into, you'll be ok.
Apr 10, 2008 | Televison & Video
Dewalt dc011 ! wont charge batteies
send your radio for repair. till the guys at the service for grc repair cost. very economical rather than you do it your self if you are not sure of the problem. radio need 3 circuit borad or also a charger
Jan 05, 2008 | Dewalt DC011 AM/FM Radio
Universal Remote Control Omega MX-650 LCD Remote Control Logo
21 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
