I got the tE error code and need to access the thermistor on a LG WM2688H to replace it. I wish there was a video or pictorial taking me step by step.
The machine is only 5 years old and hoping I can fix it myself because the nearest appliance repair person is too far away - would cost $350 with the trip fee. I just want to make sure I know exactly what I need, what everything is and how to remove, replace, reassemble. Apparently, I need to take the entire front of the machine apart just to access this and still not sure where it is.
    Scholar:
  • 133 Answers
The thermistor will be located on the heating element. Remove the back panel on the machine to see if the element is not located there first.
To strip down the front of the machine there is a video on youtube which may help, it may be a diiferent machine to yours but should'nt be that much different in the strip down. If you go on youtube and type in LG WASHER DISASSEMBLY you should find one on there by Repair Clinic, this should help you. It does'nt show the thermistor on this video but other videos about a washing machine thermistor will. Only a small bullet type fitted in to the heater element.
Hope this helps.
Posted on Jan 01, 2013
  • Sally Hampton Jan 01, 2013
    Hi Morgan, thanks for replying. I removed the back panel and the heating element is not in the back. From what I have read, the thermistor on this machine is in the front and can only be accessed by taking apart the front cabinet, which is not so easy. Per your suggestion, I am going to check out the videos of other washing machines with thermistors to see if I can get any helpful tips before I do this. Thanks!
Still getting LE code after replacing Hall Effect Sensor
i would guess you are getting a "tE" error code. that is a bad thermistor. pretty common. and it starts out as an intermittent error. it really is an easy fix. great online videos. check out appliancepartspros.com for both video and parts or repairclinic.com for video and parts. or youtube.com
Feb 22, 2016 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is wrong when tE code is displayed?
thermistor error there are 2 in there usually and one needs to be replaced.need service man for this pretty tricky job.
Jan 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error te
According to the manual, this is a control error, more than likely a sensor such as a thermistor. Call for service.
Jul 06, 2010 | LG WM2688H Front Load Washer
I have a front load LG washing machine. Its two years old and it stopped working today and it is giving a code of TE on the read out. what does this mean? Any help would be greatly appreciated!
TE is a Thermistor error.
This can be a shorted Thermistor and or a bad heater element. These items are located at the front bottom of the washer's tub.
If you have a washer with steam function. It could also be the steam generator's thermistor and or a bad heater element. The steam generator is located just behind the dispenser’s housing on the top left side.
I can get you part numbers is you need them.
Mar 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Thermistor for LG WM2688H
Thanks so much for the tip regarding flipping the machine on its side. I was about do the lengthy process of disassembling the front and I tipped the machine over instead. Lo and behold, there was the problem in plain sight right away -- the wire to the thermistor had simply come off the connector! I restripped the tip of the wire and crimped it back on the connector, problem solved. Didn't even need a new part!
Jul 07, 2008 | LG WM2688HWM TROMM SteamWasher
Te error code
btw...the thermistor can be found easily by tilting the machine on its back. It is mounted to the back of the drum housing. I removed mine after getting a "tE" error and cleaned it and replaced...no problems since!
Oct 29, 2007 | LG WM2688H Front Load Washer
I do not have a solution, but have the same exact problem and would like to know if you ever found out where the thermistor is and if you were able to fix it.
Thank you,
Treegirl
Sep 12, 2007 | LG WM2688H Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
