Question about Radio Communications
How many amps to run 350 linear amp
Silver streak 350 amp for 11 meter
    Genius:
  • 1,669 Answers
Specs call for a 20 Amp fuse so the unit will not draw more than 10 Amps!
Posted on Jan 01, 2013
3 Suggested Answers
Gavin93
  • 66 Answers
SOURCE: will 25 amp power supply pull 250-linear?
Yes it could, but... but it also depends on your antenna, what antenna are you using. Do not upgrade the power of your radio unless you know your antenna can handle the output power.
Posted on Oct 13, 2008
tscmusa
  • 95 Answers
SOURCE: need more talkpower without a linear amp
Send it to a CB shop and ask em to peak it and tune it,shouldnt cost more than 75.00
Posted on Apr 01, 2010
How many fet tranistors are in this unit and what is its max amp draw.?
There are 5 transistors in that unit that you are asking about. The amperage draw is about 50 amps
May 23, 2013 | Palomar Redman Cb Stop LD 450-fet LD Low...
2000 chevy silverado. alternator problems. start truck and meter shows about 11 to 12 amps for a few minutes then goes up over 14. Did this for several days. today started and went right to 14 amps then...
amps or volts
11 to 12 amps indicates nothing but if it is volts then it indicates that the alternator is not charging the battery
Battery voltage is 12 -13.5 volts and when charging is 14.5-14.8 volts dc
the rest of your statement indicates that the alternator or voltage regulator is faulty and you should have the charging system checked by an accredited auto electrician
Feb 26, 2018 | Cars & Trucks
Battery discharges in about 3 days if not run.
it may have deffective diode on the charging system(the alternator). 14 volts is an over charge in a battery. ampere reading must be on what the battery designed.
Mar 01, 2012 | 1997 Jeep Grand Cherokee
I hooked silver streak 250 linear to my cobra 29 lx not working
how is the radio getting out without the 250 hooked up?
Feb 19, 2012 | Cobra Radio Communications
How many amps on amp meter 1995 jeep cherokee
I think you are looking at the voltmeter, not the ammeter.
11 volts means the alternator is not charging if the engine is running. There are some conditions that exist in normal operation where the voltmeter can register 11 volts and it not be an issue, but if you are driving down the road, and only have 11 volts- the vehicle is running off the battery to keep the engine functioning for only a few miles more.
An ammeter in a car or truck has to be able to handle the full output of the alternator- which can range from 35 amps for some, up to 165 amps for others and higher. It is this reason ammeters in motor vehicles rarely have any numbers on them, just plus or minus sign, or the words charge discharge.
Feb 07, 2012 | 1995 Jeep Grand Cherokee
I have a fosgate 8"
Your ohm meter will not give you an accurate reading on a speaker.
It looks like the PL-300 is at lowest, 4 ohm stable. If it is a 2 channel amp (which
I believe it is) drive each speaker with a separate side (Left and Right).
You may damage the amp if you parallel or series the speakers.
7Here is a great site for all electronics info. See #57 on the right side pane for more speaker info.
Basic Car Audio Electronics Site
Apr 22, 2011 | Phase Linear Car Audio & Video
Power light on the amp goes on after 5 sec off ultra linear 1200
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Dec 23, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Ultra linear ul-600hc
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, do the following. I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp almost certainly has shorted output transistors and will need to be repaired.
Let me know if you have any other questions.
Aug 26, 2008 | Ultra Linear UL-600HC Car Audio Amplifier
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
