Question about MSI (MUKUA) Mouse
MSI mouse thats included in MSI S420
Ok I've been having this problem for WEEKS now and I'm getting tired of it. When I click my mouse once, sometimes, let me rephrase, its getting often now that when I click my mouse once, it does double click by itself. Can you tell me how to fix this bug? This MSI mouse should work very well since I use it with MSI laptop. Thank you.
  • Anonymous Sep 25, 2008
    I have the same problem... One click = double click... and when i work is verry annoing...
  • Anonymous Mar 27, 2014
    Sometimes I need to re-click it, other times it double clicks on its own. For instance, i'll click to answer an em,ail and it will double click and send the email.
    President:
  • 2,961 Answers
You need to check the mouse settings, go to Start>control panel>printers and other hardware>mouse and check that it isn't set to one click as being a double click, check all other settings also especially the click speed may be set too fast and is encouraging a double click.
Posted on Jun 24, 2007
Msi netbook
Try downloading ALL the drivers from msi. Windows drivers don't always work properly as they are generic.
May 23, 2014 | MSI Computers & Internet
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Should I put 22s on a 94 S420 or keep the 20s that I have on the car, or drop down to a smaller size wheel to get more tire
If you want more tire and can not go with bigger height, either you should put on a lift kit to give you more clearance or get smaller rims.
Jun 07, 2012 | Cars & Trucks
Where i can get the recovery cd for the msi megabook s420?
Unfortunately the only way to get recovery cds is to ask them from producer.
If you want to recovery your pc there may be a second way. Some producers create a hidden partition and from there is possible to recover the pc. Some of the producers install also a small utility on the computer that allow to create recovery cds.
Aug 22, 2011 | MSI MEGABOOK M510C Notebook
I was on-line Monday with knkcook (if i rememvber correctly). I was waiting while he was looking for an answer. Then the system cut us off and it wouldn't re-connect with him. I am having a problem...
Hi
  1. Insert your Windows 2000 CD into your computer's CD drive.
  2. Open Windows Explorer and navigate to "Valueadd\3rdparty\Mgmt\Winstle\Swiadmle.msi" on the Windows 2000 CD.
  3. Double-click the MSI file to install the Veritas Software Console. Specify an installation location that will be accessible by the clean PC creating the installation package.
  4. Navigate to the file named "Discoz.exe" in the WINStall folder, then double-click this file to execute the Discover tool.
  5. Click the "Before" snapshot and select the clean PC. Click "OK." Discover will take a snapshot of the clean PC before installation of the third-party application.
  6. Install the third-party application onto the clean PC and reboot the computer. Run the newly installed application on the PC to ensure that installation was successful. Quit the program, once verified.
  7. Launch the Discover application.
  8. Click the "After" snapshot option, and select the PC again. Click "OK." Discover will take a snapshot of the PC after the installation of the third-party application. In doing so, all data that has changed is recorded and compiled into an MSI file. This data includes files, registry entries and edits to settings necessary to install the application.
Lastly
Copy the MSI file to another computer and test the installation package by installing the software.
Reference
  • Microsoft : How to Create a Third-Party Microsoft Installer Package
  • CLICK HERE
Hopefully this will help you
Regards
Jun 08, 2011 | Microsoft Visual Studio Professional...
My motherboard msi g41m4-f...... no beep.....no boot....no screen.....no mouse.....fan turn ok drives are ok....help me please thank you ....Michel
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
good luck
Aug 30, 2010 | MSI G41M4F (7592010R) Motherboard
When i type my touchpad is still alive.... how can
I used to have the same problem on a couple of different laptops I had. The worst was my IBM. OK, here's how to disable it: First, I am sure you have another mouse plugged in to your computer so that you will still have mouse functionality...
Click on Start menu, go to control panel, click on mouse. Click the "hardware" tab at the top of the window, and select your built-in mouse. at the bottom of the window click the "properties button, and then in the window that opens, at the bottom you will see "device usage" over a drop-down menu. click on the drop down menu and select "do not use this device" and select ok. close out all windows. You have successfully disabled your mouse. keep theseinstructions in case you want to turn it back on in the future.
Take care.
Mark
Jun 21, 2009 | MSI Computers & Internet
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
I can not install OfficeSuite. I have Windows Vista home Premium. I had downloaded updates all afternoon and it still shows error 1719 Window installer not correctly installed. Help!
Download:Windows Vista Service Pack 1
I tried personally in WIN-XP worked same applies to Vista.
Error Message:
Error 1719. The Windows Installer Service could not be accessed. You may be running in safe mode or Windows Installer may not be correctly installed. Translation:
This message might appear when you’re trying to add or remove a program that installs via a Windows Installer MSI (Microsoft Software Installation) package file. The Windows Installer Service is the standard method for installing and uninstalling software on Windows XP. It keeps track of all of the components that need to be installed for a particular program to run and ensures that any files that are shared by programs are not removed when one of those programs is uninstalled. The Error 1719 is an indication that some Windows Installer Service files are missing or have become damaged. Solution:
The first thing to try is re-registering Windows Installer in the Windows registry. Make sure that no other programs are running and then click Start, Run, type msiexec /unregister in the Open field, and click OK. Next, click Start, Run, type misexec /regserver in the Open field, and click OK. Restart your computer and try installing or uninstalling again.
If you’re still getting the error message, the next step is to try reinstalling the Windows Installer files. In order to do this, you’ll first need to rename the existing files.
First, click Start, Run, and type msiexec /unregister in the Open field, and click OK.
In My Computer, click Search and locate the following three files: msi.dll, msiexec.exe, and msihnd.dll. They are hidden files so you’ll need to select Search Hidden Files And Folders under More Advanced Options. When you’ve found the files, rename them, by removing the .dll and .exe extensions and replacing them with an .old extension(for example msi.dll becomes msi.old).
Once you’ve renamed the files, WinXP will automatically replace them with a new copy from the dllcache (a hidden folder where copies of important system files are kept in case you mistakenly delete or rename critical system files). Restart your computer and try to install or uninstall the program again.
Finally, if neither of the above processes corrects the problem, boot into Safe Mode, and go through the above steps again, first re-registering and then reinstalling.
or
Go through the following links:
http://www.vistax64.com/vista-general/45784-windows-vista-error-1719-help-3.html
Hope this will be helpfull
Please rate me...
Thanks & Regards.
Nandu
Sep 02, 2008 | Computers & Internet
Left click of my logitech cordless optical mouse not works properly
try to set on your MOUSE, here:
start-control-panel-mouse folder
hope this can help. :)
May 16, 2008 | Logitech Wheel Mouse Optical
MSI (MUKUA) Mouse Logo
409 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Computer Links
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
