Question about LG WM-2077C Front Load Washer
Loud noise when washing
Loud noise like rocks move when washing
  • LG Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 01, 2013
How do I fix a mashing machine that is rocking?
Send model # of washer sound to me it has a bad glide on a frame
most Kenmore top load washers balance will not work if these glide are busted or missing happens when washer is moved to new location and not handled right
Feb 27, 2015 | Kenmore Washing Machines
My 2000 dodge neon has a loud noise coming from the front and feels like something is not letting the tire move freely
Safty first,Can you safely jack the frount of the car chalk the rear tires and put the transmission in nuetal. Try to spin the wheel by hand. Then take the wheel off and checked your brakes? It could be be the brake pads or caliber locking up. Or as simple as a rock stuck in there. I hope this helps you.
Feb 21, 2014 | Cars & Trucks
Washing Machine making loud banging noises when it is spinning
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
(If this has not cured the problem it is possible that the internal suspension is malfunctioning.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 30, 2011 | Kenmore Front Load Washer
Loud thumping noise when spinning. poorly rinsed
Start off by checking the machine's balance to ensure effective spinning.
John C
Jul 15, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Roxyrogers.1@hotmail.comThe tub moves back and forth and makes a loud noise when spinning
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Good luck,
John C
Mar 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
When the washing machine is in spin mode it make a loud noise.
Check to see if the sides have come loose first by tapping on them. If you hear a metal "clang" you need to re-seat the loose panel. If all sides and front are secure check to see if the feet on the bottom have become "stuck". The easiest way to do this is to rock the washer and the feet should extend and retract. If they done they need to be cleaned to allow them to move freely.
Mar 20, 2011 | Maytag Atlantis MAV6000 Top Load Washer
When i put a wash load on there is a loud rubbing noise from my washing machine it only happens when i put clothes in the machine. Is it out of balance ? Any help would be great.
Hi from retired Englishman in SW France @ 20:51 Mon evening
It is worth checking the balance always, whether it is a front loader or top loader. You do not say what make or model- but the instructions are the same for all!
Firmly push one front corner of the machine and see if the machine rocks AT ALL. If it does then the foot at that corner must be adjusted downwards until it is hard on the floor- not so hard as to lift the machine though!
If it doesn't rock from that corner then do the same thing from the other. Once certain all is OK ensure that all of the feet are locked in position by the lock nuts so that they cannot move and your machine should be balanced!
Best of luck,
John C
Jan 31, 2011 | Washing Machines
Maytag top load washer making a loud noise when spinning
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 17, 2009 | Washing Machines
LG Front Load Washer Problem
The washer is not leveled correctly.  You will need to adjust the front feet to level the machine.  Run a load of clothes in the washer.  When it gets to the spin mode, check the level of the machine by pushing the front left corner and the front right corner.  If the noise quiets down on either corner of the machine, adjust the legs on that side.
Jul 22, 2008 | LG WM-1832C Front Load Washer
LG WM-2077C Front Load Washer Logo
100 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
