Question about Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
Sthil chain saw 009 repair oil leak - Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250
  • Stihl Master
  • 1,807 Answers
More information please
Posted on Jan 22, 2013
2 Suggested Answers
johndoe541
  • 784 Answers
SOURCE: I have a 180 Sthil
hello, hawe you checked oil tank cap. Is ther air inlet free?
Posted on Mar 23, 2011
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Sthil TS 510 concrete saw(not chain saw) has a tank for oil that is empty and a tank for gas/oil mix. Inside of the oil tank there is a hose that goes into the fuel tank. Why is there an oil tank if it is...
most concrete saws ive ever used that have a chain type blade have a water tank on them for cooling the carbide/diamond tips on blade , if it's a rotary (round ) type blade these are made of a material that is designed to wear down and provide the cooling needed
you sure dont want fuel getting on cutting surface one spark and it'll burn !
Mar 09, 2015 | Garden
How to stop sawdust from coming into the carburetor section and how to adjust the chain oiler. chain seems dry.
Check to ensure the oil opening on the side of the saw housing is not plugged as well as the matching oil groove in the guide bar first. Turn the saw upside down and see if there is a + and a - sign near the sprocket on the bottom. If so, turning towards the + increases flow. Most new small saws oilers are non-adjustable.
Feb 23, 2015 | Stihl GUIDE BAR 16 in STHIL CHAINS
When cutting with saw sthil 026 it shoots sparks from the bar or chain nothing seems to b blocking bar???
First, don't cut nails as you will dull the blade in seconds. Is the safety anti-kickback bar shoved into position. That applies a chain brake that can spark if you can get the engine started with it engaged. Other than that, inspect for the chain running into stuff it should not. Assuming you have put oil in the chain bar reservoir and pumped the pump a few times to get some pre-lube on the chain & bar;.
Aug 15, 2014 | Garden
I have a sthil 026pro i know where the screw is for the ajustable oiler but what way should i turn it for more oil
Anti (counter) clocwise increases oil flow (I think - it's been a while).
you won't damage it if you get wrong. Make your ajustment and rev the saw to maximum, pointing the tip of the bar at a reflective surface (about 2 inches away) for about 20 seconds if you see a layer of liquid covering about half an inch wide then the oil is ok.
Jan 07, 2011 | Standard Oregon Chainsaw Chain For Stihl...
Chain oil keeps leaking out..how can I stop it ???
First, make sure you're using bar & chain oil, it's very thick and won't leak out like motor oils will. When you're done using the saw, store it with the blade side of the saw up. Not always convienent, but the oil will run away from the blade oil channels and not leak out.
Oct 22, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Oil leak on Remington electric chain saw model #111174-01
check oil lines and when storing saw stand on end or on side blade up.. vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
May 13, 2010 | Remington 16" Electric Chain Saw
How does the oil pump work? What drives it?
Most saws today have pumps that are driven by the chain sprocket/clutch. Some may operate from the crankshaft on the clutch side. Some older designed saws operate from vacuum/pressure from the crankcase, ie. Homelite XL, STIHL 009, McColluch Mini-Mac.
Dec 06, 2009 | Garden
Stihl 16" Chainsaw Bar Chain Saw 018 025 Ms 180 250 Logo
204 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
