Question about Magellan 2136TLM GPS Receiver
My magellan 2136 will not come on
Got it for christmas ...took out of box and charged it worked fine ...now it will not come on ...just screen saying magellan ...no futher
My magellan Roadmate 5220-LM powers on but will not go past the first screen. I have tried to use the reset button but it still will not work
Hello Liz, You may have two problems. If your unit is several years old, the battery may need to be replaced. First charge the battery overnight. To get the screen unfrozen , you need to remove the screws on the back, open the case, and unplug the white battery connection . Reconnect the battery connection after a few seconds. If this works, it is usually a temporary fix . Either your battery does not hold a charge or your charger connection is poor at best and can not deliver a full charge to the battery. It could be both.
Mar 17, 2014 | Magellan RoadMate 5220-LM GPS Vehicle...
How long intial charge before it will show the sceen
Which model do you have---the owner manual usually has this info--mine was several hours (8) but it varies by model---actually mine new in box did power up and show display fine--but I charged it full.
Nov 07, 2012 | Magellan GPS
Device will not power on
I found a Magellan Roadmate in the dumpster when I was dumping the trash off my truck.They were even so kind to leave the charging cord.I figured out that the charging cord wasn't connecting to the unit when plugged in.It took 20 minutes to figure out how to pop the case open(retainer tabs on all sides in addition to the screws).Once opened up,it took 5 minutes to repair the solder connections from the power socket to he circuit board.Works like new!
May 31, 2012 | Magellan Roadmate 2035 4370 2036 4040...
MAGELLAN GPS 1412 STUCK ON SYSTEM SETTINGS SCREEN. The GPS worked fine yesterday, I took it out of the vehicle to bring it inside to program a trip, the battery was low so I took it back out to the...
This is normal, this come straight of the satellite. To speed up process or bypass, reboot system. To Manually reboot this model, turn unit off like normal. Then when turning on, keep button down as it fires up, DO NOT release on button, keep it down until all fires up and even about 10 seconds passed, then let go. This reboots it and cleans up a lot of ****. Thanks Mike. Please if this helps, please give me 4 thumbs up, to help me and others. if that dont work, turn it off again fully charge it then reboot it manually again. This should do it!
Jun 16, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Turn on get a screen saying magellan thats it
  • Check if the unit is fully charged. Because if the unit is not charge you will just stay in the magellan logo.
  • If the unit is full charge and still stay in the Magellan logo find the reset button and press and hold the reset button for 15 seconds while its on and then release.
  • If still the same thats the time need to call the technicall support hotline of magellan if they can repair it free of charge.
  • If you need clarification feel free to reply to this solution.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 12, 2010 | Magellan Maestro 4250 GPS
Magellan Roadmate 1470 screen froze at spinning clock
Same thing happened to me. It was working fine yesterday, until I arrived at my destination, then it froze and when I restart it, it stops at the spinning clock. I'm so mad at myself for not researching the update and finding out that this is happening a lot!!
I don't think I have my receipt. It will be interesting to see if Magellan charges me for THEIR mistake!
Dec 27, 2009 | Magellan RoadMate 1470 GPS Receiver
My magellan roadmate 1212 will not stay on unless plugged into
if its not charging the battery, the meter will say full even though the battery is dead..its a very common problem with alot of gps with the usb as a charging port. my solution is if this is still under warranty, i would send it back to magellan or where ever you bought it, because sooner or later the usb port is going to totally fail and wont even start up if plugged in and your going to be left with an expensive paper weight.
Jul 29, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
My samsung tocco will not turn on! the screen turns on, saying SGH-F480, with the bar across the bottom loading up, but when the bar gets to the end, it just goes blank for a sesond, and then repeats this...
this happend to me, i think you can confuse the touch screen, i just took the battery out and put it back in again,and it worked with no memory loss or anything.
Jan 11, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Magellan 3250
Send it back GET A REFUND.. I am ditching my Roadmate 700 (cost over £800 34 years agao) .. Magellan Support is so useless, they don't respond. .. just don't seem to care - how French! (and I say this with 28 years working knowledge in France)
Am now buying a Tomtom 720T with cameras preloaded - it upadtes automatically when you sit the satnav in a cradle attached to your PC/internet.
Dec 27, 2007 | Magellan RoadMate 700 GPS Receiver
Help me please! My mp3 player shut off.
press the power button for 15 seconds and let go. leave it plugged in the battery should be charging.
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Magellan 2136TLM GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
