Question about Goodman Heating & Cooling
Blower motor turns on then shuts off after a minute on my goodman furnace
I changed the starting capacitor out because the fan would not start, it just made a humming noise like it was trying to start. Now it comes on, but only for a minute, then it shuts off, then starts the cycle all over again. I noticed the motor is getting hot to the touch. I did check some voltages on the board. I have 28 vac from the thermostat. I have 120 volts on the board.
    Genius:
  • Goodman Master
  • 1,033 Answers
The motor is shutting off on it's overload. Make sure the capcitoris the proper voltage and microfarad rating. Also, make sure two speeds are not hooked up at the same time to the motor, for example if there is a motor lead on the heat terminal, there should not be one on heat/cool terminal. If all checks out good younwill need a new motor
Posted on Jan 01, 2013
  • Arlan Jordan Jan 01, 2013
    Thanks Robert this does help. I haven't changed any wiring. The blower seems to be moving at a low speed. I think it has a high speed, but I am not sure. It puts a decent amount of air out when the fan turns, but I think it should be higher. Also the motor gets so hot, that it will burn your hand if you touch it. When you mentioned the wiring, did you mean the wiring that goes to the control board?
  • Robert Jan 02, 2013
    Yes there will be motor leads that attach to the control board
SOURCE: goodman ac/gas furnace unit mdl. # gmp075-4
i HAD THE SAME PROBLEM, TURNS OUT IT WAS THE FLAME SENSOR, CLEANED IT, AND ALL WAS GOOD
Posted on Dec 13, 2007
  • 1003 Answers
SOURCE: Goodman GMP125-5 Air Handler
REPLACE BLOWER MOTOR
if its spinning free until motor is energized motor may have bad armature or brushes.
If you energize blower and manually give fan motor a spin will it start if so replace cap.
Posted on Jan 23, 2008
SOURCE: Heater blower motor cycles on and off (frequently). I have a class 2 LR95329 Honeywell Thermostat
I had the same problem with a Coleman. The problem is the blower relay. You can find this at http://mobilehomerepair.com
Posted on Oct 21, 2008
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
SOURCE: goodman gmnt100-4b wont ignite
I had the same problem. I had to remove a return air duct filter that i had installed and it worked just fine. The system needs plenty of air flow to operate.
Posted on Jun 17, 2009
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Blower motor makes noise, but does not work goodman
its either a bad motor or bad capacitor if you try to spin the wheel by hand and it starts then its the capacitor
Dec 26, 2012 | Goodman Heating & Cooling
Goodman model PGB036075-1B when I turn on the heater the blower starts soon as the burnner starts about 2 sec. later the blower stops. then of course it overheats. What would cause the blower to shut...
bad blower motor run capacitor and or motor. Test capacitor or just replace in expensive if dont have test meters. If change motor make sure get new matching capacitor for new mtr.
Nov 15, 2012 | Goodman Heating & Cooling
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
I have a Goodman Furnace that doesn't turn on. If I spin the blower it will run, blower just buzzes and still buzzes while running. It shuts itself off after twenty minutes. I can resets it and spin the...
First I would suggest that you replace the start capacitor on your blower motor but if it is running for awhile that makes me wonder if the thermal overload is shutting your motor off. You can replace the start capacitor and then if it starts as it's supposed to and then shuts off you'll know the motor needs replaced also. I hope this helps you . THanks
Nov 30, 2010 | Goodman CLQ24AR42 Air Conditioner
Fan starts and quits several times
I will give you my best suggestions based on the information that was provided. It sounds like the blower motor is trying to come on several times unsuccessfully and then the flame is shutting off. If this is the case, here are my best guesses.
  1. If the blower motor has a run capacitor, the capacitor could be bad and the motor is trying to start but is pulling too many amps and tripping out on the internal thermal overload. You will need a multimeter that is capable of checking microfareds to determine if the capacitor is bad. Capacitors are usually marked....you will commonly see a marking of 5uf, 7.5uf, 10uf, etc... Sometimes all you need is a new capacitor. These are not very expensive.
  2. The blower motor itself may be bad.
  3. If there is a fan switch, it could be bad. A fan switch has a set of contacts that are normally open that will close when the switch heats up and send voltage to the blower motor. These will eventually wear out and act erratically if at all.
  4. The motor may not be getting the proper voltage, this too can cause the motor to pull too many amps.
  5. The most likely reason the flame is shutting off after the blower fails to come on is because the furnace is tripping on the high limit switch. This switch typically cuts the 24 volt power to the gas valve.
I hope this helps!
Oct 29, 2009 | Goodman CKL24AR24 Air Conditioner
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Jan 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Heating & Cooling Logo
238 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
