Question about Brother MFC 420CN All-In-One InkJet Printer
MFC-660CN Newish printer, cartridges OK, but middle section of the printing is blurry ? any idea what may cause this, and how to solve - maybe just cleaning the head but I do not have the instruction manual
    Problem Solver:
  • 12 Answers
Switch the machine on. Press the "Ink Management" key to the left of the screen. Go down to "Cleaning" and press ok. Chose the colour you would like to clean and press ok. The cleaning process uses a tiny amount of ink. Hope this solves your problem Good luck.
Posted on Sep 27, 2009
I am unable to print word/excel/pdf 2007 files uisng MFC 395 -CN printer
Posted on May 16, 2011
The cyan ink is not getting much through how do you clean yhis?
Posted on Apr 08, 2010
Some times it prints from my e-mails and on the net and then it will not work Help
Posted on Aug 20, 2008
    Genius:
  • 2,985 Answers
Contact the Brother Support team and www.fixyourownprinter.com
Posted on Jun 24, 2007
Mx432 Printing is blurry
Hi Steven Quick im happy to help you
When you say many documents, we talk about an amount of 200 pages, this is the case, you need to replace another cartridge.
If not that much, I can recommend to clean injectors to try to solve the problem, if you have clogged nozzles.
How to clean the print heads on your canon printer
http://www.en.rellenadodecartuchos.com/2014/05/how-to-clean-print-heads-on-your-canon-printer.html
Nov 20, 2015 | Office Equipment & Supplies
Just replaced all of the print cartridges. Now print is blurry looks like double print
First perform ink head cleaning a couple of times as follows. 1)Press Ink, 2)Press arrows to choose cleaning and press OK, 3)Press arrows to choose all and press OK. Do this a couple of times. Then you can perform check print quality as follows. 1)Press ink, 2)Press arrows to choose Test print and press OK, 3)Press arrows and choose print quality and press OK, 4)Press color start. the machine will print a chart. Inspect the short lines on the four color blocks If any are missing follow on screen instructions.
Feb 19, 2014 | Brother MFC 6490CW InkJet Printer
Faded printing issues with Brother MFC-9320
Try cleaning the corona wire on each toner cartridge. This may help solve your solution.
If this does not help try another thing.
Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended.
To see how to replace your toner cartridges check here
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
It says to replace the yellow ink, i did and still getting the same message, am unable to print
first, Examine the Ink Sensor Window to see if ink is visible through the clear plastic. Hold up the ink cartridge and look at it, if the middle section has ink in it, then most likely the sensor board is bad. Generic inks tend to cause this problem.
If you don't see ink, then the cartridge you have really is empty.
Aug 26, 2010 | Brother MFC 210C All-In-One InkJet Printer
The Brother MFC -210 does not see the cyan inkcartridge.
HELLO THERE
can u tell me if these are the right cartridges for this unit cause there is a big diference if you use the wrong cartridge if it is youare going to haveto go to the maintanence section and reset the cartridge there and than go from there ok
best regards michael
Sep 14, 2009 | Brother MFC 210C All-In-One InkJet Printer
My Brothers MFC 210C All-In-One Inket printer is printing blurry. It has been used in a year. I changed the cartridges and ran the cleaner but it still prints light and blurry. What can I do? Thank you.
keep on printing the catridges will satrt function well after few prints if they have ink and heads are ok , if not take out cartridges shake them well chek head are leaving ink on a tissu paper if not place cartridges under runing water tap clean their heads and dry them with tissue paper and place them again nowi think they will work i
let me know your reply sitehr@gmail.com
Aug 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Blurry text print with ghost image
Hey,
Your problem could be because of bad alignment. That means paper alignment and printer alignment don't match. There will be instructions in,your manual to properply align your printer.
Hope this helps.
Thanks
Apr 15, 2009 | HP DeskJet 3745 Printer
MFC 660CN
message says"removescanner cover,then reinstall cartridge," just renewed cartridge.
Jun 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Generic Problem or Brother specific? Help!!???
Thank you to coolguy88 who solved my problem by pointing out the obvious: reinstalling the drives for the printer, which I didn't know where seperate from the other parts of the all-in-one. Many thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
May 07, 2008 | Office Equipment & Supplies
Brother MFC 420CN All-In-One InkJet Printer Logo
333 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
