Question about Refrigerators
Turning off a sub zero 3211 rfd
I want to turn off the refrigerator. When I turn the dial inside the fridge to the off position, it doesn't stop the machine from running. Is there another power switch somewhere? Thanks.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Nope, that's it if you turned the one in the refrigerator and NOT the one in the freezer! It is probably a defective switch... To turn it off for sure, just unplug it!
Posted on Jan 01, 2013
    New Friend:
Replace the thermastat. the switch in the question I mean the contacts inside are stuck or fused closed and are not disconnecting when the set point is reached.
2 Suggested Answers
SOURCE: sub-zero model#3211-rfd, side by side,
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Posted on Sep 16, 2008
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
Does the sub zero model 361 rfd refrigerator have a separate thermostat control for the freezer ?
No, the 361RFD does not have a separate control for the freezer as this unit has a single compressor. The control is located behind the back panel in the refrigerator compartment and the part number is 4201470.
Jul 21, 2012 | Sub-Zero Refrigerators
Our sub-zero refrigerator has not been cooling properly and mold builds up near the bottom
My Sub Zero 561 would lose cooling in the main fridge area over time and I would usually turn the thermostat down. This helped but I'd get an ice buildup on the back wall of the fridge, especially if it was packed full of stuff and didn't allow for air movement. I finally removed everything, removed the back panel to the fridge, and discovered that the entire rear area was a solid block of ice. A defrost fixed it but I had to turn up the thermostat to keep it from coming back. Now it works great after driving me crazy for years.
Jun 02, 2012 | Sub-Zero 561 / F
Pro48 sub zero clicking
This usually indicates that the control module is bad. Trace the clicking to it's source either on the back of the fridge or inside the fridge near the controls.
Feb 29, 2012 | Sub-Zero PRO 48 Side by Side Refrigerator
I have sub-zero model 3211 red. My ice maker stop making ice. what to i do?
Here is a link to a Sub Zero Repair Video
http://www.appliancerepairlesson.com/shop/refrigerator/sub-zero-diy-repair-video-for-replacing-ice-maker/
Feb 20, 2011 | Sub-Zero Refrigerators
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 695s - plastic/rubber fridge door edge is warm
This is normal and is to keep door from getting moisture or sticking around door seal. You also can contact them at 1-800-222-7820
Sea Breeze
Mar 27, 2009 | Sub-Zero 695/O Side by Side Refrigerator
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
J
Jul 30, 2008 | Sub-Zero Refrigerators
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
