Question about Fellowes 3011001 Shredder
I have a Fellowes ps-65c shredder. If I load a piece of paper, it doesn't turn on automaticaly. If I turn on the switch the shredder runs OK in both directions. I have cleaned both sides of the paper sensor
  • Anonymous Apr 19, 2009
    I have two Fellows P-55C that don't shred automatically
    anymore. What to do?
  • 32 Answers
Its possible the sensor has gone bad
you will need to UNplug the unit , then take it apart 9 screws then gently pry it apart with a screwdriver or butter knife
you could test this with a voltmeter, one side emits a constant should have 5-12 volts across this
the other side the reciever will change its voltage when you break the signal with a piece of paper.
also ive seen chunks of plastic break off from inside and as the teeth rotate the plastic can cut the wire
Posted on Sep 01, 2009
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Ps-60 repairs
I own a Fellowes PS 60 shredder.
It could be that the sensor has trash or it is sensing something. Check it carefully if you see trash/debris cleanit with a Q-Tip or air blower - !DO NOT USE ANY WATER OR SOLVENT! -
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2013 | Fellowes Powershred PS-60 Shredder
Fellowes Powershred PS 60CC stopped working
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
My PS-65C,won't work because.............
Don,
Sorry, no spare parts are available.
Sep 17, 2009 | Fellowes 3011001 Shredder
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
Fellowes 3011001 Shredder Logo
256 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
