Question about Whirlpool Washing Machines
I have a washing mach.mod.LC4900XKD0,I replaced all rubber parts,mechnical parts are as new,only tube is rousty,I understand there are no more parta for this model avalible,but still wander,might be a replacement yhe might fit and do the trick?
  • Whirlpool Master
  • 17,130 Answers
Please check on this link for spares: www.espares.com
Posted on Jan 01, 2013
2 Suggested Answers
SOURCE: replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Posted on Apr 06, 2008
What does The "DA" on washing machine door seal rubber means ?
the issue is quite simple just go to the manufactures website and compare the part nos and part diagrams on their site eric
Jan 20, 2018 | LG Washing Machines
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
I have a coleman Mach rooftop unit & want to connect drain tubing to carry condensate away. Is there a small drip pan with a tubing conncetion for this?
If all you want to do is re-route condensation dripping off the roof, and it's a rubber roof, one easy way is to buy a caulking tube of "Dicor" self leveling sealant for rubber roofs from RV dealer, and run a 1/4"-3/8" bead across roof from AC to wherever you want it to go, and let it cure for a couple of hours. Nobody sees it, and a tube is about $10 max.
Jun 09, 2010 | Coleman Mach III Air Conditioner
The washing maching was working. Then I smelled
need to replace the rubber ,the one who moves the motor under the bolt
Sep 17, 2009 | Washing Machines
Kenmore washer odor
The most likely cause of a burnt rubber smell is a worn motor coupler.
Sears parts site
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24922200&pop=flush
Go to the sub section with the brake/clutch/motor/gearcase and item # 13 is the motor coupler between the motor and transmission.
It has three parts. 1. A plastic piece with three prongs fits on the transmission input shaft. 2. A plastic piece with three prongs fits on the motor output shaft and 2. a RUBBER grommet with 6 holes fits between them.
Over time, the rubber piece can wear and the two plastic pieces can rub against it at speed causing a rubber burning smell.
Replacing one is easy.
Remove the cabinet, the pump (2 clips) the motor (two screws and clips) and the motor mounting bracket (two 1/2: bolts).
Remove the rubber piece and pry off the two plastic pieces. Fit the new plastic pieces on the transmission and motor shafts. Replace the mounting plate. Carefully line up the six holes as you put the motor back on.
Replace the motor mounting clips, the pump and clips and cabinet.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
Hotpoint washer over filling
Hello Friend, Your solution is simple. You need to replace the water level pressure switch. It's simple to replace, just remove the knob from front panel and gain access to the rear of control panel. You will see the water level pressure switch from the backside. It has a flexible rubber tube attached to it. Just remove the rubber tube and the wires making note of location of wires. Install new switch and re-install wires and when re-installing rubber tube, be sure to moisten nipple on new switch before you re-install the rubber tube. moistening the nipple before re-installing the rubber tube will insure an air tight seal. This should solve your problem. Happy to help, Tim.
Jun 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Needs new black rubber tubing connector
my sunbeam model 7660 bp monitor needs a new part on tubing. on the inside of machine there's is a black rubber piece that connects the clear plastic tubes. where can I get a new part? thanks..
May 25, 2009 | Sunbeam Digital Blood Pressure Monitor
Samsung washing machine
clean the debris filter usually situated at the bottom of the washing maching you will need to open the panel, you should see a rubber tube with a bung in the end you need to take the bung out in order to drain the washer, once you have drained the washer you can clean the filter by unscrewing the large black round bung. hope this helps
Feb 13, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Sony KP -57HW40 - Green Picture Tube - part new/used
CONTACT VIDEO DISPLAY AT 1-318-747-0140 AND TALK TO CHARLIE I GOT MY BLUE ONE FIX IN 6 DAYS!!! AMAZING FOR ONLY $152.00 THATS CHEAP YOU JUST HAVE TO SEND IN YOUR OLD ONE AND THEY REPAIR IT! AWESOME COMPANY!!!
Nov 27, 2007 | Sony KP-57WS500 57" Rear Projection...
Washing Machines Logo
175 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
