Question about Canon imageCLASS MF5750 All-In-One Laser Printer
HOW TO FIND & REMOVE HARD DRIVE FROM CANON MF5750
For data security purposes I need to remove the hard drive from my dead Canon 5750 all in one machine. Where do I find it and how do I get it removed. Can the rest of it be recycled somewhere?
  • J Walter Jan 03, 2013
    This did not fix the problem. I need instructions on how to disassemble the machine, find, and remove the hard drive.
  • 7,627 Answers
  • J Walter Jan 01, 2013
    I need to know how to disassemble the machine enough to get the hard drive out. The guidebooks do not provide any information on this problem
3 Suggested Answers
SOURCE: error 5750
open here, maybe help :D
http://translate.google.com/translate?hl=id&ie=UTF-8&u=http%3A%2F%2Fwww.startcopy.ru%2Fbbs1%2Fmsg%2F7549.htm%3F1&sl=ru&tl=en&history_state0=
comeherespamer@gmail.com
Posted on Dec 16, 2008
Crankstart
  • 696 Answers
SOURCE: i need a driver for canon laserbase MF5750 for Mac
Sorry to inform you but this printer was only designed for Windows, although there are drivers for all current versions of windows Canon does not support this printer on Macintosh.
Looks like you may have to try a different printer,
Chris
Posted on May 20, 2009
How can I get my Canon MF 5750 downloaded to my new computer with Windows 7?
Click here Click on above link select os and download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
Aug 26, 2011 | Canon LaserBase MF5750 All-In-One Printer
Tip
Data Recovery (possible) from faulty hard drives
DAMAGED HARD DRIVE - DATA RECOVERY
Data recovery from faulty hard drives is difficult and can be costly. There is no guarentee that you can recover data from a faulty hard drive.
If the hard drive makes a clicking noise the the hard drive is dead.
First thing to try, is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an USB mass storage device (external hard drive) and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
on Jun 11, 2010 | Computers & Internet
How can we download 5750 canon printer software
Hi.
Below the link to the download page for this printer. Scroll down Canon page and find Driver download link and the rest of the software for this model:
MF5750 - Canon Download Centre
Regards.
Ginko
Aug 20, 2011 | Canon imageCLASS MF5750 All-In-One Laser...
Retrieving data from dead hard drive
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data. First thing I would try isto remove the damaged hard drive and connect it to an USB hard drive adapterand then plug this adapter into a working computer's USB port. If thiscomputer sees this hard drive as an external hard drive and you can open thevarious folders and files, then I would backup your data. If the hard drive is notdetected then the hard drive is dead and data cannot be retrieved with thismethod.
Aug 14, 2011 | Computers & Internet
Canon 5750 Won't print the color, although it's set to do that, and cartridges all have ink in it. I deep cleaned and also ran a nozzle check ... but don't know how to interpret that. A = 0 B = -1 C =...
Hi Sue, first tell the exact printer model, because MF5750 is laser printer B&W, lbp5700 is also laser and doesnt have ink.
Wich ink printer do you have like pixma 5300? pixma 4300?
The 5750 doesnt exist in canon range of printers.
But, by your description you have print head problems or clodged inks or purge unit problems.
Aug 28, 2010 | Canon LaserBase MF5750 All-In-One Printer
Describe how to remove hard drive from canon
what you will have to do is remove the back cover.
then you will need to remove the thin metal cover laying flat cover on the back half of the copier just under the doc feeder. should be 3 screws.
then there is a metal box that holds the main controller on the right. if you open that you will see the IDE cable which will run up and out of that box and will run up under a thin metal plate that should be held in by 2 screws. if you remove those screws you should be able to see the hd .
if you can't get it out and or find it please call me it might be easier to explain. over the phone.
C & S Canon Copier Repair
(858)414-8475
Jun 17, 2010 | Canon imageRUNNER 6000 Copier
Acer Aspire 5100 will not boot
Two possible Solutions:
1) The Hard Drive has come unseated - Disconnect the Power and REMOVE all connections, Close the Screen & Turn your Laptop Upside Down and Remove the Battery, Locate the Hard Drive Access Panel and Remove the Screws from the Panel, Remove the Panel, Remove the Hard Drive. Carefully Replace the Hard Drive, Replace the Panel and Reconnect the Battery & Power Supply. See if the Computer will Start
2) The Operating System is Damaged OR the Hard Drive is Dead - You will need to slave Your Hard Dive into a Second Computer and Backup ALL you Personal Data OR RISK loosing it. If the Second Computer can NOT read the Drive, the Hard Drive is Dead (A Computer Repair Company may be Able to Help)
Once your Data is Safe, you can try to Repair the OS by Booting your Computer with the Drive in it. Begin pressing F12 or F10 at bootup (Once a Second). You will be presented with an Options Page for:
System Restore (FIX WINDOWS)
System Recovery (Wipes your Computer and Retores the Factory Software)
Hope this Helps!
Dec 22, 2009 | Acer Aspire5100 Notebook
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Main drive assembly
check this site: http://www.precisionroller.com/find/canon_imageclass_mf5750.htm
Jun 04, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
123 people viewed this question
old marine
old marine
