Question about Hotpoint RVM1435 Microwave Oven
Why hotpoint forms plastic burning smell - Hotpoint RVM1435 Microwave Oven
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Smoke and burning plastic smell in microwave oven
Burning plastic, not food? A component has overheated badly then, with a plastic case. The main suspect would be the high voltage capacitor in the magnetron supply. This is cheap and easily replaced ONLY IF you know what you are doing and can diagnose the fault. If you don't then DO NOT take the case off the unit as fatal voltages can be present inside even if the unit is unplugged.
I'd just buy another, as they are generally uneconomical to have repaired by a service tech.
Dec 31, 2013 | Sharp R-1610 Microwave Oven
G.E Microwave model JVM1860 Burning Smell
you must open inside see the diagram, and see 1) burn cable 2) fuse 3) diode 4) capacitor 5) magnetron 6) bulb etc.
God bless you
Nov 22, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar microwave burning
Toss it, when the electronics burn up it isnt safe to use anymore. Or especially with microwaves cost effective.
Sep 21, 2012 | Goldstar MV-1526 Microwave Oven
I open the door to the refeg and it smells like wires are burning. I unplugged it. The lighting fixture is loose. The plastic around the light is defected.
A loose connecction of the bulb holder can heat up and burn the holder plastic material -- as a faulty connection will spark and heat up. The best option is to remove the holder , rewire and replace the unit.
Jul 02, 2011 | Microwave Ovens
Comes on and kicks breaker smells like something is burning
if you smell burning then i would say the transformer is burning and if will trip breaker . some times the mag has failed causing over load to trans and both will have to be replaced. this is a big buck repair . you may want to replace ..
Jan 04, 2010 | Hotpoint RVM1435 Microwave Oven
We brought a Tesco microwave at CULLOMPTON Tesco, Devon last week. It cost £29.00 on its first major use - cooking potatoes for ten minutes - smoke seems to be coming from beneath the machine - it has...
This is almost certainly some of the protective oils and varnishes which were applied during manufacture flashing off.
All new products of this type do this to some degree but your description seems to indicate that it's much worse than normal with your machine.
Ordinarily, you can expect this to cease after a few uses and if the level of smoke and odour you've described is to be expected then the instruction booklet should say so. But as yours has visible smoke and a burning plastic smell I'd recommend that you exercise your rights under the Sale of Goods Act and return it to Tesco for a full refund or replacement. The smell of burnt lubricant is one thing, but a burning plastic smell means you can never trust the oven to be safe: none of the many microwave ovens which I've dealt with have ever smelled of burning plastic unless there was a fault.
You won't find any objection from Tesco as they do have good customer service; and when I lived in Cullompton briefly earlier this year the local branch was even better than usual at keeping customers happy.
I hope that you have found my reply to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 05, 2009 | Microwave Ovens
Microwave not working
The main controller board, or one of the power supplies has failed and require to be replaced.
You should take the microwave oven in for an estimate. I strongly suggest to not service this type of appliance yourself unless you are trained and experienced in microwave oven service.
There are many safety issues when servicing microwave ovens.
Jerry G.
Apr 04, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Hotpoint RVM1435 Microwave Oven Logo
65 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
