Question about Boating
No spark 1990 30 HP Johnson outboard ???? - Boating
  • 11 more comments
  • C.Allen Jan 01, 2013
    come on someone where do i start ? I put in new plugs.I won't to go fishing
  • C.Allen Jan 03, 2013
    I disconnected the the power to the kill switch, and checked for spark by turning the motor at the starter relay , Still no spark.
    Where is the power pack, and how do I check to see if it is ok??
    How do you hold the flywheel to remove the nut. I have a puller , but no flywheel holder.
    A little history on how this started.We were mounting a rod holder on the boat rail at the left rear of the boat, and drilled into the power cable that feeds the lights ,fish finder ,etc.We had to replace the cable,as the cable melted before we could uncouple the battery.What parts could we have damaged??
    More info .I typed in my model number to order a manual and i have a 1989 model !!!!
    I was sussessful in removing the fly wheel nut by tapping on a short socket bar. I tried tapping a longer socket bar ,and as soon as I changed to the shorter bar the nut came off!!!
  • C.Allen Jan 07, 2013
    Now I an having trouble removing the flywheel. I bought a harmonic balancer puller, but so far the flywheel will not pop off?/My fly wheel takes 1/4 By 20 threads bolts which did not come with the puller. The bolts are small , and I am afraid that they break off ???
  • ray gallant Jan 07, 2013
    find a machine shop and buy hardened ones the right length and size.
  • C.Allen Jan 12, 2013
    The fly wheel popped off .We used a 2lb BB hammer with a hefty 2 whackds . My helper was also prying up on the fly wheel with a pry bar . Npw how do I check the power pack to see if it is ok? This ia a 1989 model engine with the igni , module is under the fly wheel..
  • C.Allen Jan 13, 2013
    The pry bar was just a large screw driver.The hefty swats with the BB hammer did the job !!!! --- I dis-connected the leads from the power pack to the charge coil, one of the leads attached to the charge coil fell into my hand /Maybe I found my no spark problem? I ordered a new charge coil today .I don;t have a peak voltage adaptor instrument so I am not sure the power pack is ok //
  • C.Allen Jan 16, 2013
    Can you check the power pack without using a peak voltage adaptor instrument with your multimeter???
  • C.Allen Jan 19, 2013
    No spark problem is solved .When we removed the flywheel we found one lead to the charging coil not connected .The power pack mounting screws were loose and contacting the fly wheel.The vibration between the two parts could have caused the loose coil wire? Any way we put it back together and it is working fine.!!! Thanks to everyone for your comments and support; Challe
    Top Expert:
  • Boating Master
  • 42,984 Answers
Check kill switch , possibly power pack failed
Posted on Jan 02, 2013
captainjeffq
  • 52 Answers
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Posted on Apr 13, 2009
  • 23 Answers
SOURCE: I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Posted on Jul 07, 2009
  • 95 Answers
SOURCE: 1964 johnson 9.5 hp outboard runs but no reverse.
Pull the stablizer pins and row back to shore, lol j/k. Did you check the linkage to make sure it was working properly, look on the motor itself not on the feel of it..
Posted on Aug 11, 2009
  • 27 Answers
SOURCE: 15 hp johnson outboard misfiring
possibly c/shaft seal
ie induction collapse
Posted on Sep 07, 2009
Editor925
  • 285 Answers
SOURCE: 40 Hp Johnson outboard motors stalls out after a
May likely be one of two problems:
1. Fuel flow: Make sure fuel tank vent is open and not blocked while engine running. Check primer bulb is working and no air leaks along hose anywhere. Check function of fuel pump and ensure fuel is getting to the cylinders.
2. Overheating: Check engine isn't overheating and that water pump is operating properly while engine is running.
Posted on Sep 17, 2009
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How to set timing on 75 hp johnson outboard
creates an impulse to the cid as a magnet passes by . not much adjustment to timing small screw toward the front that moves the stator perhaps a 1/4 inch .
Aug 17, 2015 | Johnson Evinrude Timer Base, 6 Cyl 75-85...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
1968 evinrude starflite 100 hp no spark
Some of those had a battery ignition with a short cap and rotor, and some had a magneto which reached down into the bucket. Both had points and condenser like an old car. The cog belt location was critical. 2 teeth off and it would not fire. the key switch was wired diferently for each ignition system.
Jun 19, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
I have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
i have a 1977 85 hp johnson outboard it started and idiled for about a minute and now i cant get it to fire at all its got good spark possibly not getting fuel but is there anything else i should check
May 06, 2010 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Hi got a 1997 johnson outboard is a denso w24fsr spark plug ok for this motor cheers shaun
Stick with the NGK or try a Champion. A Johnson outboard is the only brand motor that will perform well with something besides a NGK.
Feb 28, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
Does an 85 johnson outboard motor 15 hp have
Not ignition points as a set of breaker points as we know it.The timing is set from magnets set under the flywheel.Hope this helps
Sep 02, 2009 | Sport & Outdoor - Others
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
Boating Logo
281 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
