SOURCE: Can't pick up all the signals
I always tell people to carefuly read their instruction manual and consult the product tech support before determing that there is actualy a fault with their unit.
If sounds like the tuner module or the controler board for the tuner may be failing, or there is a power supply distribution fault to the tuner section and or its controler. This has to be service by the manufacture.
One of the criteria I recommend when people buy an expensive appliance or TV is to make sure that there is local authorized service. I also recommend an extended warrany for expensive items. The warranty is like insurance. You may or may not need to collect!
Jerry G.
SOURCE: LG LCD HDTV 'NO SIGNAL'
To fix the problem, try turning off the TV and unplugging it from the outlet. Once unplugged, push the power button and hold it down for 1 minute. Then turn the TV back on and rescan for channels.
If the problem persists, contact LG customer service immediately as there is a problem with the memory card. The device is unable to retain scanned channels for immediate feedback.
All LG LCD automatically comes with a 1 year manufacturing warranty. You would have to provide proof of purchase to show when it was purchased. Hope this helps. The Guru
LG customer service: http://www.lg.com/us/support/index.jsp
SOURCE: I have a Seanix LCD
Your remote control should have a button to select the Source signal, which should bring up a menu with the list of available soures. If Digital or DTV is shown as one of the soures then you should be able to select this and attempt to tune in the digital signal. If this is not present in the source list then your TV is unlikely to be digital. A digital TV remote control will also have extra buttons for digital TV e.g. GUIDE, SUBTITLES, EPG.
SOURCE: After a storm, TV registers
Hello
you haven't given the brand name and model numbe of TV here. yet I posts this solution assuming that it to be LCD tv. You says that the Tv works with converter and not works with digital box. Check the digital box for any malfunction. I can oly give you this much advice as your post does not tell exatly what the fault is. If you want anymore assistance from me, please be clear out the situation you faces now. OK.
