Question about Whistler 9mm Wireless Inspection Camera
Camera lights on whistler inspection camera not working
It seems there is a bad connection in my whistler 9mm inspection camera-the lights sometimes aren't working
Whistler 2270
Double check all the connections that plug into the display unit. Make sure that the positive and negative connections are secure- especially the ground. If this doesn't help, call Whistler at 800-531-0004 for more options.
Aug 18, 2014 | Whistler Vehicle Parts & Accessories
Seems like I have no power to the heater..
could be the connection at the blower motor. inspect the contacts and post your findings. the blower motor may be going bad (high resistance) this may burn up the terminals at the connection or inside the motor itself
Apr 17, 2014 | 2001 Hyundai Accent
The lights work intermittently and sometimes don't work at all on my Whistler 9mm inspection camera. How to fix?
I guess you will need to open the case up from the panel where the lights are visible. If you can, look for loose connections to the leds or the wires from the leds to the rest of the panel...good luck!
Jan 01, 2013 | Whistler 9mm Wireless Inspection Camera
Can this unit be repaired?
do you guys have them on the same channel
Jul 12, 2012 | Whistler MC100 2-Way Radio
Have a whistler 3000, and power is going to the unit but no lights are visible and unit seem to be working
First this is not a Whistler model, its a Fuzzbuster model. Does the unit 'Beep" when you turn it on? Does the lights flash during this time as well? If so, then the unit maybe working but not picking up signals.
Nov 25, 2010 | Fuzzbuster F3000 Radar/Laser Detector...
I picked up a wisler 1190 SW radar detector at a yard sale and it seems to work. anlike my escort it only beeps once is that mormale
It should alarm to known locations such as door openers as these operate on the same band as police radar (X band and sometimes K band). That model is no longer serviced but you can trade it in for a newer more powerful Whistler however. For more information contact whistler at info@whistlergroup.com
May 25, 2010 | XRS - 9675 Radar Detector
Headlights dont work
Somewhere a poor connection is the cause. The year model indicates that some miles might be on the car.
Open the bonnet?hood and inspect for a bad joint or some wire that is rubbing against the body.
I will buy some electrical switch cleaner and spray the connectors. Just remember to let the connection dry before trying again, you don't want to short and blow something.
Sep 30, 2017 | 2003 Pontiac Grand Prix
94 ford explorer brakes
HI, i recommend inspecting the brake peddle switch located near the brake pedal foot lever under the dash. this switch may be malfunctioning or the wires that connect to the switch housing may be lose as well.
If the switch checks out ok, i would then move to the entire wire inspection. Inspect the wires that run to the brake lights to see if they are lose or torn or corroded. if you notice any lose or corroded contact clips, re[place the entire wiring that connects the brake to the electrical current and switch.
Most of the time its bad wires but, dont forget to check the switch that is linked to the brake peddle. this is a known problem spot also. these switches can go bad over time...
May 12, 2009 | 1996 Ford Explorer
Whistler 9mm Wireless Inspection Camera Logo
65 people viewed this question
Top Whistler Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Whistler Heating and Cooling Expert? Answer questions, earn points and help others
