Router bits will not lock in the router, they fall out
    Genius:
  • 1,669 Answers
There are alot of different routers on the market and alot of different shaft sizes for the router bits. There are also a number of shaft size adapters that can be found at good hardware stores that can be purchased to solve your problem. May I suggest you walk into one of them with your router and some sample bits and ket the sales people find you the correct adapter!
Posted on Jan 01, 2013
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
How does one change the bit in the B & D router?
Nearly all routers have a locking pin that you depress to lock the rotor then you should have a set of wrenches that came with the unit to loosen the mandrel and release the bit. Then just reverse the process to install the new bit.
Jun 25, 2011 | Black & Decker 11A 1 Router
How do I change bits....have not used router in years
Most routers have a "Pin" that can be depressed to lock the router spindle. But first, rotate the spindle to match a small hole in the spindle with the pin. With the spindle locked in place, use a wrench (routers often come with this) to loosen the "collet" which holds the router bit. The collet nut will turn counterclockwise when loosening the nut, when looking directly at the bottom end of the router bit, i.e. when looking down at the router when the router itself is up side down.
To install a bit, reverse the process above. Do not overtighten. About a on-eighth turn past handtight will suffice. The collet or the threaded end of the spindle can be stripped out.
Hope this helps.
Apr 27, 2011 | Garden
Bit is stuck and cannot remove it. Have tried pretty much everything.
This was posted under chainsaws. If you are asking about a router bit, I have found that taking the collet out with the bit still in it and putting it in a vise. Tap from the bottom with something and it should come out. Be sure to have something underneath to catch the bit. I have done this and had the bit fall and break on the floor...
Please post back if you aren't asking about a router.
Handie Andie
Mar 25, 2011 | Garden
I have problem with my collet in my router. As soon as I tread the nut on the collet squeezes to the point I can't get a bit in. If I put the bit in the collet then try to tread the nut on it will not...
Never tighten a router collet empty. This will bend the collet smaller and it will be too tight.
Simply replace the collet. Call the Mfg the collet may be off specs a few thousands of an inch.
When not using the router store the nut loose on the threads enough it doesnt fall off.
Feb 19, 2011 | Freud FT2000E 3 Router
The bit in my Stanley ratchet screwdriver does not lock into place, falls out when screwdriver is pointing down
There is a small springs steel wire that fits into the chuck. the bit slides into the chuck and then into the spring and the spring holds the bit inside the chuck. This ring seems to be missing. Thus the bit falls out. You might try going to a hardware store and they make a device that is two magnets held together with a rubber band. When they are together there is a small hole in the center. You can slide any screwdriver or bit into the hole in the center and it magnetizes the bit or driver. Magnetizing your bits should keep them from falling out of the ratchet screwdriver.
Dec 04, 2009 | Tools & Hardware - Others
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
I need help on how to replace bit on router craftsman style
You didn't state the model number. The older Craftsmen routers had a red lever lock on the top of the router, one position allows the spindle to turn, the other position locks the spindle. Here's the instruction for the older style routers:
  1. Unplug the tool.
  2. To lock the spindle press the red button in and slide it to the locked position.
  3. Unlock the height adjustment knob.
  4. Raise the router motor using the height adjustment collar until you can get a wrench onto the collet nut.
  5. Loosen the nut until it turns freely.
  6. The bit may still be locked in the spindle, tap it gently (not on the blade!).
  7. The bit will come loose in the spindle and can be removed.
  8. Replace the bit, tighten the nut snug but don't use excessive force.
  9. Unlock the spindle, returning the red lever/button to the free position.
  10. Adjust the height of the bit as you wish, then lock down the motor using the locking knob.
Mar 19, 2009 | Craftsman Tools & Hardware - Others
The plunge lock "slips" when the router is used in a table
You can try to adjust the lever that moves the plunge and see if that helps, but a plunge router isn't made for upside use. If you have the option and use the router upside down often, you may want to get a fixed base.
Jan 01, 2009 | Bosch Plunge Router
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
