Question about Porcher Home
Porcher cygnet c/c btw toilet - Porcher Home
5 Suggested Answers
  • 1206 Answers
SOURCE: I have a Porcher one-piece toilet with a bad
if you are talking about the wax ring you remove the floor mounting bolts and replace the wax ring under it. first you want to shut water off then flush to empty tank and with a wet dry vac remove any water left . now you can remove it without any mess.
Posted on Jan 06, 2010
  • 5 Answers
SOURCE: Porcher 6.0 Lpf / 1.6 toilet. Plumber said he
Try replacing the flapper, they are cheap and so long as the tank and or bowl are not cracked you can replace all of the internal parts and basically have a brand new toilet much cheaper then replacing the entire unit. Go down to your local hardware store and everything you need is in one simple kit with very simple instructions. Good Luck.
Posted on Jul 22, 2010
SOURCE: I have the porcher veneto
I too have the same toilet seat that needs replaced. Porcher just told me there is NO replacement seat that can be used and they no longer make nor have stock of this toilet seat. I have a local company looking into the problem and will get back to me. For now I am going to take detailed measurements of hinge placement and length/width etc, and take a tape measure to every home imporvement store in the area. Anyone with any other suggestion would be greatly appreciated.
Posted on Jul 15, 2011
  • 88 Answers
SOURCE: I have a porcher sandpiper
A few things to check look in the tank make sure nothing is blocking the flapper at the bottom thats the thing that lets the water drain into the bowl if it is clear check make sure the chain or line that connects the flush handle to the flapper is not kinked causing it to hold the flap up enough to let the water drain. If these are ok sometimes sediments will make the float device, whether its a ball or a canister type to stick reach in and lift the floater if the water stops then adjust the floater some have a screw on the canisters to adjust some an arm some the whole mechanism shaft screws up and down to adjust if its the ball hold the metal arm firm next to the base and bend it slightly down on the other end so the ball goes further into the water so when you release it lifts it up better don't bend to much check and bend more if you need to. If its a ball make sure water is not getting into it by feeling if so replace it. If none of these work you can replace the whole thing for around $20 just turn the water off flush the tank get all the excess water out and go to town its not hard make sure you have pipe tape and if you don't know about the tape ask the hardware dealer to explain how it goes on just a couple wraps. The hardware store can help you pick the one you need tell them what yours looks like and they can help find a replacement.
Posted on Sep 16, 2011
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
Feb 19, 2015 | Porcher Home
Trying to remove Porcher Posh BTW toilet. Screws in side of bottom unit do not "undo". They are loose but do not unscrew from base. I have loosened cistern but that is all - "loosen". Screws again undo but...
Removing toilet seat hardware can be a problem, especially as it is prone to corrosion - but it can be done. You can attach a pair of gripping pliers to the nut, apply thread lubricant, and unscrew the bolt from the top OR you can use one of those blade-and-handle hacksaws to cut off the nut OR you can use that little hacksaw to cut off enough excess bolt length to allow a socket to engage the nut and allow the bolt to be removed from the top.
Oct 31, 2013 | Porcher Home
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
Porcher Toilet Lid Hinges are loose
Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
Aug 29, 2012 | Porcher Toilet Seat Veneto 70032.001
Where do I get porcher 83420
Hello--
That particular model has been disontinued; however, you may want to contact Customer Service to see if there are any spare parts in stock.
http://www.porcher-us.com/contact.aspx
Paul, ASB
Sep 20, 2011 | Porcher 83420-00.000 L'Expression Toilet...
Need to gt the top off of a porcher toilet we can't fogure out how to get into the tank to fix whatever continues to run
I'm not sure why this is a challenge. The lid should just lift right off unless you have a wall mount toilet. Here is a .pdf of a typical Porcher toilet and how it all goes together. There is also a handy trouble shooting guide. If the toilet is running the culprit is either a faulty flapper or fill vavle. Let me knwo if I can be of any further help.
http://www.porcher-us.com/assets/documents/porcher/install/Install_3337.pdf
Jul 31, 2010 | Home
Jul 21, 2010 | Porcher Home
Home Logo
60 people viewed this question
Top Porcher Home Experts
Donni Steen
 John
John
ray gallant
Are you a Porcher Home Expert? Answer questions, earn points and help others
