Question about Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive
HOW CAN I FIX DPC WATCH DOG VIOLATION ?
COMPUTER SHUTS OFF AND RESTART DUE TO DPC WATCH DOG VIOLATION.
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Netflix blocked
Somehow you have established Blocker set to stop communication with Netflix. This could be due to a recent installation of a Virus Protection program, a Change of your protocol re: the Security under Internet Options, making the on line restrictions go from low to High. many things can do this.
Mar 25, 2014 | Fortinet, Inc. Computers & Internet
Nokia 3110 10 second auto off solutions
If the phone restart itself after few seconds frequently this problem occur due to enable or Watch Dog Timer (WD timer) so at this stage we need to repair Super Doungle by using some repairing tools likeMX KEY/Turbo flasher etc.To fix this if you are not a mobile tech better to contact mobile repairing shop.Good luck "Thanks for visiting fixya"
Oct 20, 2011 | Nokia 3110 Cellular Phone
My hp pavillion computer shuts down same time nearly every day.
This is probably due to having a scheduled task that shuts down your computer. Check your scheduled tasks, and delete the restart entry.
Mar 23, 2011 | HP Pavilion a450n PC Desktop
The computer shuts down on its own, stay on for about 5 mins. I made everything is plugged in.
Restart the computer in safe mode (Press F8 key when you restart computer and see the dell log untill you see the Advanced boot options, choose safe mode using your up and down arrow key and hit enter).
you system will load the basic windows drivers and will not connect to internet.
Please keep your system on and work with it for some time and test it. Even in this mode if your computer restarts then its definitely due to heat, else its due to application errors or driver errors
Dec 25, 2010 | Dell Inspiron 1525 Notebook
Dell laptop every once in a while shuts down completely, im wondering if its over heating.
Please keep your system on and work with it for some time and test it. Even in this mode if your computer restarts then its definitely due to heat, else its due to application errors or driver errors.
Dec 24, 2010 | Dell (6F858) Cooling Fan
Computer shuts down
Your computer is most likely overheating.
Make sure it is positioned so that none of the vents are blocked on the unit.
Check it with your hand to see if it's overheating, make sure dust is not blocking the vents.
If the issue persists, could be software or a failed cooling system on the unit.
Jun 28, 2009 | HP Compaq Presario V2000 Notebook
FinePix Image Memory Card reader DPC-R1
Usually the filename is how they are sorted, i.e., 001.jpg, 002.jpg, 003.jpg.... Check on the camera's setup menu to see what method is being used for file naming (for instance, it may be organizing based on date stamp, instead...).
Aug 05, 2008 | Fuji FinePix S7000 Digital Camera
Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5" Internal SATA II Hard Drive Logo
185 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
