Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Spin problem clothes are not spinning dry least not as dry as they use to and i am using the same is actually a whirlpool design 2000 ,year unknown
  • Anonymous Feb 22, 2009
    I have a Whirlpool duet 2004 model that is not spinning the clothes as dry as they should be. Any suggestions.
  • Whirlpool Master
  • 909 Answers
Bit of a dirty job, but tilt the unit back and remove inlet and outlet pipes to the drain pump motor. Look for any type of restriction like lime build up or the like. Is drain pump inlet and outlet clean etc. Finally does drain pump pump properly.
Posted on Jan 28, 2009
Our whirlpool wfs1285aw doesn't seem to be spinning and drying out clothes enough when Finished. The clothes are still drenched. Any ideas how to rectify this? Is there a filter that needs cleaning?
the rinse section spins slow while the rinsing is in process as this does 2 things
spreads the water through the clothes for a proper rinse
spins slow to equalize the cloths around the bowl
when the rinse cycle is finished and the tap is shut off it goes into a high speed spin
Your problem sounds like the program is not going to the high speed spin cycle and that would indicate a problem board
call a technician for a proper diagnosis and quote
Sep 15, 2016 | Whirlpool Washing Machines
Clothes don't spin dry enough
you mean to say the clothes are tangled with each other tightly right?
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Washer would spin dry but the clothes is still wet
Sounds like your transmission is starting to go bad. It is not creating enough power to spin fast enough to dry the clothes. A new transmission is going to run about 400 I would start shopping for new machines. Do light loads of laundry til you get a new washer..
Jul 14, 2011 | Whirlpool Washing Machines
Whirl pool washing machine doesnt spin dry
If it wont spin at all, check the lid switch. If it will spin but not fast enough to spin the water out of the clothes, it sounds like the clutch could be slipping.
Aug 08, 2010 | Whirlpool Washing Machines
Washer will not spin clothes "dry".
Lgm0923, we're sorry to learn of the experience that you've encountered with your Washer. Have you tried the troubleshooting suggestions on page 5 of your User Guide? The link is below.
If further assistance is needed, please email us your name, address, contact number, model and serial number at
Oct 24, 2017 | Whirlpool CAP2761K Top Load Washer
The washer does not spin
depends on whether or not you can ring out enough water to allow your dryer to actually do it's job and not get broken down by the excess weight of the overly wet(not just damp) clothes your trying to dry.My question is. Is it worth the back-breaking work your going to have to go through just getting the clothes dry enough for your dryer?
Dec 05, 2009 | Ovens
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
237 people viewed this question
Dan Webster
Dan Webster
Sal De
