Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
Asus P5QC mobo won't recognize personal storage through USB
Just installed this new mobo last week. Have mouse and keyboard etc etc hooked up in the USB's in back and they work fine. But i tried to plug in a flash drive to both my front USB's then the backs and neither will read. The port is getting power because my drive lights up, but windows gives me an error saying it's unreadable. Have tried with 4 different flash drives including one out of the box. Also tried hooking up my ext HD and won't read it.
    Problem Solver:
  • 9 Answers
I have this problem too but i know if you disable usb2 in bios it will solve the problem but speed is too slow and i cant solve this problem (speed)
my email:majidasadi2001@gmail.com
Posted on Feb 04, 2009
  • 3 Answers
What system are you running ?
Posted on Jan 19, 2009
Why cant i get my 4x 2gb ddr2 800 to work on my asus p5qc mobo? it will run fine with just 4gb 2x ddr2 800 but when i add the other 2x ram i get black screen at boot
Be sure to check which slots you are putting them in, stay within the same colors as to which needs to be put in.
This may be why, looks like your using DDR2
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots!
This may be the case for all speeds of DDR2
http://www.asus.com/Motherboards/Intel_Socket_775/P5QC/
Jul 16, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
How do I setup my wireless mouse and keyboard
Need more information but normally you would hook up the infrared device or usb device to the laptop. Then you would make sure that the keyboard and mouse has new batteries in it. At that point windows should recognize the mouse and keyboard. You may have to push on the connect buttons on the keyboad or mouse to get the laptop to recognize them.
Other then that its not really hard. Just time consuming if it doesn't take right away. Most of the time you don't need software installed unless the manual tells you to install them because windows will recognize them.
May 29, 2011 | Acer Aspire Z5600 PC Desktop
I purchased and Pointer Service installed DEsktop Dane-Elec PCIE 1x usb 3.0 card with 2 ports.I connected the mouse and keyboard into these 2 usb 3.0 ports.My motherboard asus p6x58d premium did...
This is an very new model of addon card for which there is no driver in the Express Gate - which is just a stripped down Slackware Linux operating system - so the system ignores it and everything plugged into it. Since adding a Linux driver (which doesn't even exist at this moment according to the manufacturer) to an embedded OS like that is extremely difficult you should just connect your keyboard and mouse in another onboard USB socket - if necessary use a $5 hub which you can buy at Walmart.
Feb 28, 2011 | Computers & Internet
MSI RS482M4 Mobo not recognizes USB port on XP SP2-3 boot.
Try to find application that load the CPU at 100% by seeing TASKMANAGER.
To start TASKMANAGER press CTRL+ALT+DEL on the keyboard, select PROCESSES TAB, click on CPU to order by CPU load and find process that come near to 100%.
Oct 18, 2009 | Computers & Internet
Unpluging 4 pin power on mobo Pc starts but no video,keyboard etc
how do i fix the monter I tryed to put the power and rest on and motherboared comes on not the monter
Mar 13, 2009 | ASUS P4SGX-MX Motherboard
Trying to install windows and at the boot screen have my keyboard and mouse plugged in windows doesnt see it.. I tried the USB keyboard and nothing I just recently replaced the MOBO using anti-static wrist...
I have seen this before, and the best answer I can offer you is some Motherboards are better than others when working with usb devices while no OS is in place. I actually tried using usb / to / ps/2 adapters and it still would not recognize the usb keyboard in a couple of instances. I had to get a ps2 keyboard for the installation of windows. After windows was installed I hooked up the usb keyboard and it worked fine. (just speaking from my own personal experience here)
Sorry I do not have a more technical answer for you but I'm almost 99.9 % sure this should work, providing there is no problem with the ps2 keyboard port on the Motherboard. I have never failed to install windows unless there was another hardware based issue of some kind, but never a problem with a known good ps2 keyboard.
Just double check everything is seated properly and try to get into the bios setup, if you cannot use the usb keyboard for this, you can try the usb / ps2 adapter, but if that doesn't work either then use a regular ps2 keyboard. That should work fine, then after setup is complete, windows is installed, then your usb keyboard should work fine.
Mar 03, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
My computer is not recognizing the new exteranl storage that I bought
Hello Tewabech,
Have you tried different USB ports? Does the drive require a seperate power source?
- Vincent
Nov 22, 2008 | Computers & Internet
Asus M2N keyboard problem
You don't need a driver for a PS/2 keyboard nor a USB keyboard. The keyboard lights should lite up at post. After boot press the Caps Lock key and it will light the corresponding light on the keyboard if the controller works. If not it is the motherboard. If you are strapped for bucks get a mobo that can use the same cpu, RAM and drives. Good luck, Steve Medley
Nov 06, 2008 | Computers & Internet
Logitech wireless keyboard and mouse (ex 100) won't connect
The mouse and keyborard have to be in direct view of the reciever. Even a small obstruction will effect the operation
Nov 02, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
209 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
