Question about Kenmore 24032\24036 Top Load Washer
Kenmore elite washing machine mod.110.24954300 type111
Water fills up in the beginning close lid and the aggetator? starts right away before the water shuts off. when it goes in the spin cycle it keeps filling so at the end of the cycles i still have water in the tub.i shut the water off and set it to spin and it drains fine??????
  • 63 Answers
You have a bad timer.
Posted on Jan 20, 2009
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
I have an elite kenmore top load washer. With the lid closed the washer will fill with water, but the wash or spin cycle will not start unless the lid is gently pushed down on the upper left side of the...
Lid switch has gone bad...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 22, 2010 | Kenmore Washing Machines
My Kenmore elite 100.24942301 Lid switch problem
You may can slightly bent the part the lid contacts so it will be depressed further thereby making the switch. If that doesn't work then you will need to replace the switch.
Dec 29, 2009 | Washing Machines
Machine fills with water then will not start wash ( lid is closed
Check he lid switch and or replace it, should fix your problem.
Nov 25, 2009 | Kenmore Washing Machines
Cycle won't start
the lid is not making proper contact with the lid switch, easy repair.
the lid is held to the maintop with a set of hinges. The left side hinge actually doubles as the lid switch actuator. so youll need to lift the lid, and feel for the opposite end of the hinge assy. when you feel the metal "arm " for lack of better word. youll need to bend it slightly towards the back of machine( usually use a hollow shafted screwdriver) as you bend backward the lid will want to close, so apply a little pressure. Your bending the "arm" to make better contact with the switch which ismounted tothe underside of the main top assembly. Before starting open and close the lid a few times and listen for the "click" of the switch activating. then recheck after bending youll hear a big diff
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washer will not agitate. After starting the washer the water will begin to fill but when it's time for the agitator to begin it shuts the whole machine off.
If the lid lifts up from the front, tighten the hinge screws on both sides of the lid. If the screws are tight open and close the lid..listen for a click.. no click..lid switch is bad.
Jun 12, 2008 | Kenmore Washing Machines
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
214 people viewed this question
Sal De
fordexpert
Robert Rankin
