Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Height adjustment knob wont adjust anymore, its loose. was turned too hard.
Can a detailed drawing be found? maybe a part fell off.
  • candy Jan 03, 2013
    the plate seems to have a permanent way to sit. how can i make/force it to "fit the knob?" knob remains loose despite handle down n on its side solution. the knob and plate dont sit with eachother.
  • Bissell Master
  • 18,394 Answers
Height adjustment does not work
Hello! The vacuum does not move up and down when you change the height setting. When the handle is reclined is when the height of the nozzle will adjust. Hope this was helpful!
Jun 26, 2014 | Hoover Tempo Widepath Upright Vacuum -...
Height adjustment not working
Manual says to tilt the vacuum back so the front wheels are off the ground (unit turned off of course) and make the adjustment. May take some back-and-forth force, but should adjust. If not, then something is jamming the switch.
Apr 19, 2013 | Eureka Smartvac 4870 Bagged Upright Vacuum
Still dont know hot to get height adjuster knob to work. tried handle all the way back n lay on side solution that was offered. the plate has a permanent place to sit. hows it possible to bring knob
Hey, not having a working height adjustment can be a bear. Lock the vacuum in the upright position, change the knob to desired setting, and recline the handle for adjustment to occur.
If you are still having difficulty, you may want to have your vacuum inspected by a Qualified Technician at one of our Authorized Service Centers. Here's a quick link to assist you in locating one.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 03, 2013 | Bissell 6594 PowerForce Bagless Upright...
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
I have a dirt devil vision wide glide, 086700, made may 2006. I found 2 places with reasonable prices and the same excellent explosion diagrams. www.ereplacementparts.com and www.vacpartswarehouse.com hope...
Do you know how to get the height adjustment knob to release the wheel height? Its stuck on high carpet? The knob moves but doesn't change the position?? Identical Vacuum.
Feb 27, 2011 | Dirt Devil M086700 Vision Bagless Upright...
My roller bar doesn't seem to be working, but I checked the belt and it appears to be fine, but a bit loose. Is this the problem? dial on front to determine heighth is also very loose and does not click...
If the brush roller stalls when it comes into contact withthe carpet, it might be that the tensioner spring has broken off. This is adesign flaw in the Eureka4870. The symptoms are: 1) brush spins until it contacts the carpet then itstalls, 2) the brush lever for setting floor/carpet is loose and lacks a firmsetting, 3) vacuum no longer has the feel of being self-propelled on carpet. Itis not very easy to repair and I don't know if a replacement tensioner iscommercially available. To fix it yourself:
  1. Remove the base plate by the 3 Phillips screws.
  2. Remove the brush roller and belt.
  3. Remove the black accordion hose connecting the motor housing to the clear vertical riser on the side of the vacuum. Unscrew it from the riser. Then disconnect the accordion hose from its black connector that screwed into the riser. Then unscrew the Torx T-20 screw that holds the bottom of the hose into the motor base. Then draw the accordion hose out through the underside of the vacuum.
  4. From the underside, remove the 3 Torx T-20 screws that hold the red top cover in place. They are located between the brush roller and the two small height adjustment wheels. The middle screw holds the height adjustment knob. The other two straddle the height adjustment knob.
  5. Turn the vacuum upright and remove the red plastic cover. This is the most difficult step. Use a flat screwdriver to pry it loose in the hole where the accordion hose fed through. On the other side, where the foot operated upright release lever is, you will have to pry the red cover off. I broke the red plastic loop from here. But it still reseats OK.
  6. Still upright, remove the belt tensioner by the 5 Torx T-20 screws, including the one connecting to the slotted arm (it has a wide cylinder under the head). Before removing the piece, note that there appears to be another mounting hole like the four standard mounts. This is the anchor for the spring which applies tension to the tensioner. The other anchor point for the spring has probably broken off, and the spring might be dangling loosely or even missing.
  7. Remove the tensioner unit. Locate the other anchor point, which is probably a broken tab with a hole as the anchor point, broken through from the high tension of the spring. This is the aformentioned design flaw.
  8. Drill a new hole near the broken tab. I drilled two, at right angles to each other. Drill small holes so as to not weaken the remaining plastic. I drilled ~1 mm. Holes should be between the two anchor points so as to not make the spring stretch longer than the original. Plus, a longer anchor point will interfere with the butting of the plastic edge when in the stretched position. If the spring is already lost then use a replacement that is ~1 inch long (total length) with hooks at each end.
  9. Reassemble the tensioner device. Check the operation of the tensioner lever to ensure smooth, firm locking.
  10. Reassemble the red plastic cover (3 screws including the height adjustment knob).
  11. Reassemble the accordion hose, brush roller, belt, and base plate.
It now works as good as it every did. I will next be seeking a replacement tensioner device from Eureka or a shop, since Isuspect this modification may eventually weaken and break. The plastic springanchor points are definitely a poor design by Eureka.
Sep 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
My front wheels fell off how do I fix it. there is a slender long spring and I don't know where it goes
That spring connects to a slot beside the height adjuster knob and a hole in the base to the wheels that fell off.The problem is you can't get the wheels to go back in flush so the height adjustment works.The vacuum will not be close enough to the floor to get any type up suction or brush contact.To change that spring as well as the belt,remove the cover by taking out two screws,one on each side.Force the rller out by prying the right end out of the slot.
Feb 23, 2010 | Eureka 2997AZ Bagless Upright Vacuum
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
A
Sep 21, 2009 | Vacuums
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
416 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
