Question about Canon PowerShot A520 Digital Camera
E 18 problem
The lens on my Canon digital camera will not close... i am unable to take a pciture and do not know the reason for this....when the camera is put on i am able to see my old pictures but when i click to take a new picture the screen is blank..i dont know what to do...please help...i have the canon power shot sd 500 camera and the problem that appears is the E18...... please help me I turn on the camera and it just says Canon then it beeps around 5 times and turns off.
  • Anonymous Jan 24, 2009
    my camera lens willnto close, it powers on and makes a sound says error and restart...how does this get fixed??
t00nz
  • 4738 Answers
SOURCE: E 18 problem
Your A410 problem really sounds like it might be a defective CCD imager. Canon would normally fix this for you for free, including free shipping both ways. http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Unfortunately this is only for applicable cameras A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
But you may want to contact canon anyways to see if they will help.
As for your SD500 e18 issue,
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Posted on Nov 16, 2007
Nick Spirov
  • 35 Answers
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Posted on Jan 09, 2008
MrsJGreen
  • 130 Answers
E18 is a lens error and needs to be serviced by Canon. You may qualify for an upgrade to the S3 IS for a deep discount if you are interested.
Posted on May 30, 2008
Same problem - gray screen, error message of E18 in bottom left corner. Unable to take pictures and lens will not retract.
Posted on Sep 29, 2008
  • 56 Answers
I dont know what error E18 means, check cannon support for that, but welcome to the world of DISPOSABLE CAMERAS, I have replaced 3 cameras in 3 years, 2 because of lens and shutter issuses.
Posted on Jan 26, 2009
E 18 problem
Jan 26, 2009 | Canon PowerShot S2 IS Digital Camera
E 18 problem
Please follow the directions found here.
Jan 07, 2008 | Canon PowerShot A570 IS Digital Camera
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 12, 2009 | Canon PowerShot A400 Digital Camera
E 18 problem
Jan 08, 2009 | Cameras
E 18 problem
Try to use a diffrent memory card it will fix the problem
Aug 04, 2008 | Cameras
E 18 problem
I have the same issue "E18" on my powershot A95 and i don't know how i can solve it. Sorry. Loic
Jul 15, 2008 | Canon PowerShot A95 Digital Camera
E 18 problem
I just had the same problem. I sent the camera to the factory repair place and they fixed it in 5 days free. Even tho the camera is two years old and out of warranty.
Mar 01, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A520 Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
