FixYa.com
Tags:
Bosch SHU5307UC Built-in Dishwasher
Prolonged washer cycle time (by 3 users)
posted by Winnjamm on Jun 24, 2007
My washer is taking too long to complete. The "delay start time" keeps popping up with 2H, which I think means 2 hours delay. I have tried resetting the washer. I have adjusted the delay time to "0 H" which I assume means zero hours delay. But it keeps resetting back to 2H. What can I do to get it back to normal?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by fionaC1, posted on Jun 23, 2008
I have no LED display but a pump runs when you turn it on. I have found the same solder splat but re-soldering this does nothing. Is the low voltage PSU on this same board? I suspect the board but where can you buy new ones?
Comment by Guest, posted on Feb 18, 2008
displays 2H on everything except quick wash and rinse and hold. Does not complete the quick wash cycle.
Best Solution
posted on Jun 25, 2007
Thanks for Trying (70)
Oshie
Rank:Master Master
Rating: 79%, 37 votes
Hi!
I'm not familiar with this model, but it sounds to me like there is not a problem!
If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less.
Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results!
Hope this helps!
C.
Rating Locked! (?) Winnjamm has rated this solution as Thanks for Trying
Solution #2
posted on Jun 27, 2007
Rotu
Rank:Guru Guru
Rating: 91%, 477 votes
These dishwashers are notorious for burning a solder connection on the control board. If you can get the board out and can solder, you can fix it yourself for free. it will be obvious where the problem lies once you open the control board housing, if thats the issue. Otherwise it sounds like you will have to replace the board. Unless of course this is the way it's always operated, but I doubt you'd have posted this if that was the case.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Jul 01, 2008
Not Rated (0)
sjvpi
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've had this problem a couple of times, and the culprit was a bad control panel. Last tech to replace it said that if you go to run it, and 2H comes up automatically - the control panel needs to be replaced.
This Problem Also Relates To: Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Bosch SHU33A05UC Stainless Steel Dishwasher Bosch SHU9916 Dishwasher Bosch SHU43C05 Stainless Steel Built-in Dishwasher Bosch 24 in. SGI30A05 Built-in Dishwasher Bosch 24 in. SHE66C05UC Stainless Steel Built-in Dishwasher Bosch 24 in. SHX56A02UC / SHX56A06UC Built-in Dishwasher
Can you Help with these Dishwashers problems?
Dishwashers
Hotpoint FDW20 Dishwasher...
Hotpoint FDW20 Dishwasher... Answer This...
Dishwashers
model wqp12 bfe bottm rotor
model wqp12 bfe bottm rotor not... Answer This...
Dishwashers
I have a miele dishwasher
I have a miele dishwasher and... Answer This...
I own two. Cycle times...
As mentioned, I own two of... Answer This...
feed to electronic valve
my spi5432gb/01 has stopped... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
