Question about Kenmore 22422 Top Load Washer
Replace water inlet valve kenmore stack washer 131779900
aborcass
  • 2651 Answers
SOURCE: Kenmore Elite Quiet Pak 1 Model No.110.26942503
yea if valve is leaking into machine when not on youll need to replace the valve. part number for the inlet valve 3979346 . you can find a diagram as well as a part list at sears.com.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=UFaeD4IGtGIcYFtrZmj97w**.shcapp3205?modelNumber=110.26942503&pop=flush
Posted on Mar 26, 2008
jsrock516
  • 5911 Answers
SOURCE: water inlet valve Kenmore dishwasher
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Posted on Jul 09, 2008
  • 127 Answers
SOURCE: kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Posted on Dec 23, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore 90 series need to replace the inlet valve
This is actually a simple repair that the average Do-It-Yourselfer can perform with just a little guidance. The following link explains all the steps necessary to replace a water inlet valve on a Kenmore top loader:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If you have questions along the way, please let me know. A replacement valve can be purchased online at searspartsdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. All these sites offer competitive pricing and excellent service, so shop all of them for the best price. Use your model number for your search criteria. If you do not wish to order on line, use the part number found at the sears or appliancepartpros website and go to your nearest appliance parts retailer. This is a part that is commonly carried as part of the in store inventory. I hope this helps you.
Posted on May 24, 2009
  • 89 Answers
SOURCE: Kenmore Washer/Dryer Stack -- Need to replace Washer
first of all. comming from a Sears Technician.. (don't yell) -- the delivery drivers only know about delivering stuff. they dont know too much,
if the two are the same size they can be stacked.
sometimes have to rig something up
and yes, for that model the top is removed, clips go on the rear and screwed at the front.
in some areas it is sold seperatly as a stacking kit
Posted on May 28, 2009
Not filling
The water inlet valve is stuck shut and will need to be replaced. Here is the part you need.
Oct 19, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Stackable Washer cold water does not work
Hello there
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
It should look something like this picture below
Nov 09, 2010 | Kenmore 98702 Stacked Washer/Dryer
My stacking kenmore washer dryer will only run hot water.
That would be a problem with your water inlet valve. Before checking that make sure the screens in the hose is clear and when you disconnect it from the washer there is a screen inside the valve. Here is a video on checking the water inlet valve. Different unit but procedure is the same. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water will not shut off in washer. Even when
Replace the water inlet valve - it is stuck open. Send model # from tag on appliance to help@timerking.com for part # lookup. Hope this helps!
Nov 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer will not fill with water
Assuming that you have power to the machine and it switches on the most likely cause is a faulty water inlet valve of a faulty logic controller board. The water inlet valve is the most likely problem and is a cheap and easy repair. Call a service engineeer asap.
Sep 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
When washer fills it does not stop unless done manually
HI, i recommend testing the timer/control device for faults. make sure it is spinning and not shorted. if the timer/control device is in good condition, this will confirm a serious fault in the water valve assembly(inlet). replace this device in this case.
May 22, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Ty for being here. I have a kenmore stack washer
Inside the machine you have a valve called inlet.
The inlet water valve will collect the cold and hot water lines, and open alternatively one or the other during cycle.
To access the inlet valve you need to take apart the machine, and that is not an easy task.
If you DIY remember to unplug power, there is high voltage running inside your appliance.
Below the inlet valve for your model:
1014350
Mar 05, 2009 | Kenmore Washing Machines
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Low water in 98702
Check the water-inlet valve for cleanliness, and functionability then replace if necessary.
Aug 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 22422 Top Load Washer Logo
56 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
