It is possible that the mice had habited within the washing machine and when it was shipped it must have got stuck within and so had done this damage to bite off the wires. Now all what could be done is to check the colour coding of each wires and JOIN them with care making sure that it is not mixed. Once this is done I am sure the washer will work, make sure to remove and clean and BLOCK all passages to the wiring section.
Have you tried replacing the plug on that cylinder ? Might be bad . Also I would replace the wire to the injector that the mice ate. Could be damaged in more then one place.
You do not say which engine trans you have or are wanting. The 3.1 or 3.4 crate engine new will cost about $1,886.00. The 700r transmission will cost about $1499.00. Then the 350 crate engine will cost about $1695.00 up. Plus shipping.
Canvass the prices of the other freight forwarder, or cargo handlers running the route and compare it with your existing one. But canvass only the reliable forwarder. Send your e-mail for your comments. By the way, I am also a cebuano pinoy.
cut the wire and re connect with crimp connectors and then seal withe heat shring tubing and a heat gun (put the tubing in first) or you could solder the ends together and heat shrink tubing over the individual wires. So long as you have a good water tight connection ther should be no adverse affects to your equipment.
