Question about Canon Speedlite 550EX TTL Flash
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
  • Bruce Carlson
    Bruce Carlson Jan 02, 2013
    Yes - I know - It is sync, not sink.
    Champion:
  • 254 Answers
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Posted on Jan 15, 2013
SOURCE: Not working with my Rebel XTI
My problem with the xti and speedlite is underexposed pix by 1 2/3 stops... anyone else with this problem?
Posted on Nov 19, 2008
SOURCE: canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Posted on Apr 15, 2009
  • 685 Answers
SOURCE: canon flash speedlite 550 ex ttl
Send the flash back to canon for Service this is not something that can be fixed in this forum. Do not use the flash the burning smell indicated a potentially dangerous problem and fire hazard.
Posted on Nov 24, 2009
SOURCE: My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Posted on Jan 07, 2010
  • 102366 Answers
SOURCE: I would like to download a manual for my Canon
Try this page on the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=7394
Posted on Feb 15, 2010
The flash on my canon eos 60d not working
Possibly the spring that raises it is broken, or there is foreign matter in the hinge. Can it be raised manually ?
Oct 03, 2016 | Canon EOS 60D Digital Camera
Canon 60d internal flash
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
Flash wont sync with 60d (tried several at dealer) Problem is the flash - not the camera
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings. It might work for you as it has for me in the past.
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Use of Canon 60D's wireless function to control power on Canon 430EXII, being operated manually.
Your flash will fire optically. This is wireless but not radio.On the flashgun window move through the options until you see all of these in the window :- Flashing M, MZoom (24mm)
(the power output eg) 1/4
Flashgun icon CH1 Slave (blank)
The front panel should show a flashing red light. This means it is ready to receive the light signal from your onboard flash. From the camera menu select the in built flash control.
Set it to - Built-in flash - CustWireless
Flash mode - Manual flash
Wireless func - (single flashgun icon)
Channel- 1 ch
firing group - (flashgun icon)All
(flashgun icon) flashoutput - 1/64
selecting 1/64 should be sufficient to trigger the flash gun but not light the scene.
Manually pop up the onboard flash
In the view finder you'll see a number of green bars when half pressing the shutter and wait for them to go down to one which mean the camera and flashgun are communicating, fully press to take the shot and the flash (off camera) should fire.
Jun 26, 2017 | Canon EOS 60D Digital Camera
Using canon Speedlite 300TL on Nikon D80 camera
The Canon Speedlite will work, but you won't get the full functionality of a Nikon Speedlight. Most importantly you won't get the through-the-lens metering.
Mar 05, 2012 | Nikon Cameras
Getting the promaster 7400edf flash to meter properly with canon eos 60d
The flash model for Canon is 7308 it might be the correct flash but programed for the wrong brand/manufacture. The way I see this flash is that Promaster produces this 7400edf to work on all the major camera brands but it's programed for a specific camera. The flash firmware updatability is done by a dealer. Another thing I ran into with one of my students cameras (a Canon) was you needed to go into the menu to select external flash over internal. I believe Canon is doing this due to the video capabilities of the camera.
Apr 05, 2011 | Promaster 7400EDF Flash for Canon EOS
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in flash to pop out when needed.
I have tried turning the power off and on again. The problem persists.
Dec 19, 2010 | Canon EOS 60D Digital Camera
Canon Speedlite 550EX TTL Flash Logo
227 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
