Question about Canon Speedlite 550EX TTL Flash
Flash wont sync with 60d (tried several at dealer) Problem is the flash - not the camera
    Master:
  • Canon Master
  • 442 Answers
Try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings. It might work for you as it has for me in the past.
Posted on Sep 07, 2014
2 Suggested Answers
SOURCE: 420 ex does not sync with the shutter, pre flash only
I have the same issue with a speedlite 380EX and a EOS50D. what did you finally do ?
Posted on Feb 15, 2010
The flash on my canon eos 60d not working
Possibly the spring that raises it is broken, or there is foreign matter in the hinge. Can it be raised manually ?
Oct 03, 2016 | Canon EOS 60D Digital Camera
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
  • is your settings set to manual ? if you are set to manual mode and the flash does not pop out try pressing the flash button located near the EOS 60d label
  • if the flash won't pop out after pressing the button try to follow the steps on this you tube link
How to fix the This menu cannot be displayed External flash is attached...
Aug 17, 2014 | Canon EOS 60D Digital Camera
60d flash
Spring assembly malfunction inside camera that applies the pressure to pop open the flash.
Jan 25, 2013 | Canon EOS 60D Digital Camera
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Getting the promaster 7400edf flash to meter properly with canon eos 60d
The flash model for Canon is 7308 it might be the correct flash but programed for the wrong brand/manufacture. The way I see this flash is that Promaster produces this 7400edf to work on all the major camera brands but it's programed for a specific camera. The flash firmware updatability is done by a dealer. Another thing I ran into with one of my students cameras (a Canon) was you needed to go into the menu to select external flash over internal. I believe Canon is doing this due to the video capabilities of the camera.
Apr 05, 2011 | Promaster 7400EDF Flash for Canon EOS
Canon 60d internal flash wont work. No error message at all. Doesnt work by pressing flash button either, no noises at all after pressing. Thanks
you have to take it out of auto mode to have any control over flash, try putting it in P mode then press the flash button which is next to the flash. if this doesn't work, take it back to where you got it from to take a closer look.
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Can't activate internal flash of new 60d
Feb 02, 2011 | Canon EOS 60D Digital Camera
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in...
After I have detached my external flash (Nissin Digital Speedlite Di622), my Canon EOS 60D does not recognize the fact that the external flash is already detached. Thus, this does not allow the built-in flash to pop out when needed.
I have tried turning the power off and on again. The problem persists.
Dec 19, 2010 | Canon EOS 60D Digital Camera
Canon Speedlite 550EX TTL Flash Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
