Question about Rock & Ice Climbing
How do i take apart my jt outkast paintball gun
I need to take it a part to clean
2 Suggested Answers
  • 111 Answers
SOURCE: Do I have to take
No, you didn't do anything wrong...
Paintballs come in a variety of sizes. That difference is very hard to see with the naked eye, but your barrel knows what fits and what doesn't. Players have a choice in barrels and ID-internal dimensions, so the balls are various sizes as well. You will have to sample a few brands and see what works best for you.
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
Paintball gun
Paintball guns that are semi-automatic are generally more reliable and rugged than their electronic counterparts as they have a smaller number of moving parts. They are particularly preferred by beginner and intermediate level players who are discovering how to play the game, relying on a reliable gun rather than player skills. To get the guidance you may look on to Paintball Gun Buying Guide.
Jan 18, 2014 | Sport & Outdoor - Others
My Tac-5 Recon marker does not shoot the paintballs. I cock the marker and after I pull the trigger I can feel and hear the spring action but no paintballs are launched. When I attached the CO2 tank I did...
take the hammer and bolt out, clean them and oil them with paintball oil (no motor oil or WD-40)
air tool oil also works, but besides paintball and air tool oil, never use anything else.
the bolt is in the front of the marker, it is what pushes the paintball from the breach into the barrel. the hammer will be towards the back. its been years since i have touched a tac-5
easiest way to oil is just to put a few drops in the asa (where you attach the tank) and dry fire with the barrel off a dozen times. this will get the oil everywhere it needs to be.
if you can take it apart and clean it i would still recommend that
Jan 05, 2018 | Tippmann A 5 Standard Paintball Gun
I dont know how to used my jt tetra paintball gun
I recommend that you will post your question under the correct category (Indoor Games) it will be easier for Experts to answer your question.
Jul 21, 2012 | Sport & Outdoor - Others
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
Do I have to take the gun apart to get the battery in the gun??? and also before i was done with the gun my brother put the paintballs in the hopper but for some reason they were falling out of the...
8^)
Nov 03, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun problem
First off, make sure it's clean, and lubed with a quality oil made for paintball.
If you're sure the o-rings are good (as in relatively new) it's pretty hard to tell just from looking as it doesn't take a lot of damage to leak air.
Try a different tank, just to be sure. Make sure it's full.
**** it. If that stops it there's a clue.
If it's had some use it's possible to have a bad/weak spring and the valve isn't closing entirely. Make sure your velocity is less then 300fps.
Check out your local airsmith or field and they should be able to get you squared away if none of that helps.
8^)
Apr 30, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Took it apart and don't know how to reassemble
How To reassemble an Army alpha black paintball gun.
Apr 23, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Rock & Ice Climbing Logo
223 people viewed this question
Top Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
Betty L Kidd
Betty L Kidd
ray gallant
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
