Question about Miele S7260 Bagged Upright Vacuum
Suction is low - Miele S7260 Bagged Upright Vacuum
  • Miele Master
  • 18,424 Answers
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
Low suction
I suspect the hoses are plugged with debris.
Apr 21, 2017 | Hoover L2310 GUV Central System Vacuum
Brush turns....suction low! Attachement works, no
Check for a blockage between brush and entry into dust chamber, if something has not made it's way to the dust chamber could result in low suction1
Dec 08, 2009 | Dyson DC14 All floors Bagless Upright...
Low suction
1) Have you checked the filter? If it is clogged your suction will be low. Also, you could have a pipe loose where you can't see. Make sure that you can get a coin to go all the way through the hose. make sure the suction motor ( the unit ) is coming on.
2) Call the repair man.
Aug 10, 2009 | Electrolux Central Vacuum
Bissell Lift Off pet revolution vacuum losing suction
You may have a clog in the hose. Unhook the hose and see how the suction is there, if ok, then check the dirt inlet by the brush roll. If suction is low at the hose, then there is a clog in it.
Mar 20, 2008 | Vacuums
Miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Mar 05, 2008 | Vacuums
Low suction
Is the suction low at the tank after you disconnect the hose? If it is strong there, then the hose may be clogged. You can unhook the hose from the wands to see if you have suction or not. If you do, then look further down all the way to the brush roll. The other possible is if no clogs, check the filters, on the E series, there is a filter on the back, there is some also had one in the top and you would have to take it apart to get to it. One other is that the motor is not running at top speed and may have to be replaced. It can sound ok, but will have reduced suction. If you suspect the motor, check your owner manual, some of these newer ones had a long warr. period on the motor.
Feb 13, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Low suction
Is the water seal in place or missing? Another cause would be a bad motor, running at a slower speed will mean low suction. If it is a motor, then you would have to replace it. Is the suction low at machine without the hose, if it is ok then may be a clog in the hose.
Feb 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Low Suction/No Soap
Check the seal at the bottom of the dispenser, it needs to be on the valve not sitting in the hole, part 2101795 if you need to replace it. If suction is low, check the filter on the bottom of the tank lid, if clogged, suction will be low. Also check window gasket, sits between the tank and the nozzle window, if missing, you won't have any suction part #2104052.
Sep 28, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Miele S7260 Bagged Upright Vacuum Logo
282 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
