Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
My husbands wedding ring fell into the lint trap of our Maytag front loading dryer. Anyone know how we can get it out?
  • Maytag Master
  • 17,130 Answers
You can remove the lint filter to retrieve the RING, please do not put the machine to any wash until the filter and drain pump is removed and checked.
check this link.; Cleaning lint filter
Posted on Jan 01, 2013
  • 183 Answers
SOURCE: Maytag Washer top load
very difficult, the is a filter within the drum area but not easily accessable. you could try removing thesump hose and try to clean through the hole, otherwise major job. Regards Advisor
Posted on Aug 22, 2007
SOURCE: Maytag Atlantis top-load washer has a big lint problem
My dryer is making a noice and will not start how do I open it to see if the belt is broke
Posted on Jan 17, 2009
  • 20 Answers
SOURCE: Dryer Lint Trap Not Catchin Lint
If you have the ability to move your dryer away from the wall and look at the hose located at the bottom of the unit.
1. Take the house off it might be clogged 2. check for ang gaping holes in the lint screen
Posted on Jan 19, 2009
aborcass
  • 2651 Answers
SOURCE: Coin Stuck In My Dryer
well, i can get into the machine, not aproblem.. is the coin perhaps trapped inside one or more of the innerr drum viens perhaps??? anyway, ifyou removet he2 screws securing the door, and the 2 screws opposite the hinge, the front "u" shaped front panel will tilt off fowards.. from there theres a few 5/16 screws holding the main top assy to the froma of machine, you can remove them and tilt the top back, giving you acess to the outer drum assembly( and you can removethe drum viens and retreive te hoffending "coins" in htat fasion.. hope this helps.. TURN OFF POWER TO UNIT<< LIVE WIRES!!!!!!!
Posted on Feb 12, 2009
james klgr
  • 362 Answers
SOURCE: I'm receiving my 3rd Maytag bravo 400 tomorrow,
make sure the vent exhaust from dryer is not stopped up clean it out if is then should be fine
Posted on Jun 21, 2009
How to get into the trap where objects from pants pockets end up
The trap you are referring to would be the drain pump. The following link explains how to access and clean out the drain trap on these pumps:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Read through the link provied and let me know if you have any questions. I hope this helps you find what you are looking for.
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
Lost my diamond wedding ring in washer. Where could it get stuck? My husband took the front off the washer, and opened the drain filter..nothing :( Could it get caught in the hose?
it could get caught in the water pump or between the water pump and hose outlet, it could be caught between the agitator and the washing machine tub or it could be in the **** Trap in the wall, since it's heavier than water it would be the most likely place. and if not there then the over fill tub on the sides.
Jun 13, 2009 | Kenmore Elite 45986 Front Load Washer
Individual package of detergent fell into lint trap of Whirlpool
HI, You should remove it. Here is how Normal 0 UNPLUG the dryer! Remove the two screws under the lint screen and pop the top up by inserting a flat blade screw driver in the gap between the front panel and the top. Remove the rear panel of the dryer and locate the four 5/16" screws that hold the lint screen housing to the bulk head. Pull the lint screen housing away from the bulkhead and reach in to remove the item that fell.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 28, 2009 | Whirlpool LER5636P Electric Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Lint fell back into lint trap. how can i get it out? already looked in back.
An appliance store can sell you a brush that is attached to a long wire. It is made specifically for removing lint from dryers. I have seen them at walmart and other places but for sure at an appliance store. Good luck.
Apr 20, 2009 | Whirlpool WED5100SQ Front-Load Electric...
My lint trap has very little lint.
Older clothes do not produce as much lint as new ones. Also, if your dryer isn't getting as hot as it used to, then you won't get as much lint either. Does it seem to take a bit longer to dry your clothes? Also, check your dryer vent, if the airflow is reduced, the amount of lint that is expelled through the filter will deminish as well. You may have a build up of lint in the vent ducting to the outside that is restricting airflow.
Apr 08, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune Dryer is taking over an hour to dry a load
Check the exhaust vent out back of dryer to see if exhaust pipe going outside is crimped or blocked. Let me know if air flow is better if pipe is pulled off back of dryer. Thanks, Sea Breeze
Mar 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Retrieve ring
is the lint trap on top of or inside the door?
Oct 30, 2008 | Kenmore Dryers
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
267 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
