Question about Pool & Spa
Waterco S600 how do I change the sand - Pool & Spa
4 Suggested Answers
adamh294
  • 310 Answers
SOURCE: How do I replace the
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
Posted on Nov 01, 2010
adamh294
  • 310 Answers
SOURCE: How to change sand in a Poolrite S600 filter
Here is a link to very thorough instructions.
http://www.ehow.com/how_4999132_change-sand-pool-filter.html
Here is a link that will take you to a page with the specifications for your filter. This will tell you how much sand and aggregate to use.
http://www.poolrite.com.au/system/specs/7/original/Microsoft_Word_-_POOLRITE_MEDIA_FILTER_AND_SPEC.pdf
Hope this helps.
If it does, please rate me positively
john224
  • 1378 Answers
SOURCE: when waterco sand filter is
Thank you for posting your question here on Fixya.com.
Since you already replaced the gasket you will need to check two others things: First, inspect the groove the new gasket is sitting in as well as the mating surface of the diffuser. Be sure none of the old gasket is still there. Thoroughly clean all surfaces as well to ensure the new gasket is fully seating in the valve. If that does not cure the leak you will need a closer inspection of the mating surfaces to find a crack. Without any pump pressure on the valve it will be tough to find. It will appear as a hair like line but once the pump is on it will open up enough to let water pass. If you find a crack you can try to use a two-part plastic approved epoxy to seal it or else you will need to replace that part.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Nov 18, 2010
How much sand goes in a waterco 8600 sand filter
Leave 10"-12" empty space above sand (freeboard).
Dec 18, 2016 | Waterco Pool & Spa
I have a waterco pump and sand filter and can't get a high flow thru the pump to operate the creepy crawly
see if it works on recirculate if it does change sand or backwash if suction based and you have multiple inlets close the ones not being used if it is connected to a pool return close the other return valves or plug them while cleaning
Sep 14, 2015 | Waterco Pool & Spa
How do I change the sand in a sand filter model t500
Remove top of filter tank, use shop vac and vacuum away.
Mar 03, 2015 | Waterco Pool & Spa
How do i remove the top of a waterco micron s600 sand filter
REMOVING 40 MM (1.5 IN) SCREW-IN TOP MULTIPORT VALVE.
1. Check filter base is bolted or 'pinned' to slab/paver. Mine was not.
2.Undo piping connections unions and pull back piping as much as possible to get access to Pump Inlet and Waste connectors.
3. Use two lengths of 25 mm (1 in) HARDWOOD dowel about 600 mm (24 in) long or hammer handles, on each side pushed inside PE body of MPV as far as will go inside each connector.
4. Curse and swear and lever hard anti-clockwise until friction grip of thread releases but valve body not damaged (you hope) and can use hand grip onto valve body to unscrew..
This was the hard part no-one spoke about on the web sites.
5. Follow suggestions for unit opening as described everywhere.
6. Use a wet suction vacuum to remove the sand fill. So much easier. I bought a 15 Litre (1.5 gallon) Homelite budget unit. Best investment ever and can use for other dirty cleaning jobs.
7. If you need a new sand filter, buy a model with clamp-on Victaulic type mounting for a stress free life, not a screw-in MPV..
Oct 25, 2013 | Pool & Spa
Pool & Spa Logo
811 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
