I have a honeywell thermostat and its all programmed correctly but my heater only kicks on for about 5 minutes then shuts off. How can I fix this?
    Genius:
  • 1,033 Answers
Do the burners ignite?
Posted on Jan 01, 2013
  • Phillip Sparkman Jan 01, 2013
    Yes. I'm an idiot but I didnt even consider the easiest most obvious solution (change the filter) but once I did that its been running like a champ! Thanks
machtcl1
  • 61 Answers
SOURCE: heater comes on at 5:10 am prior to the programmed setting
Access the installer setup menu (You will need the installation manual from the t'stat to do this) and turn off the "intelligent recovery" feature. This feature turns the equipment on in order to bring the conditioned area up to temp at the set time. Or you could set the "wake time" to 6:50!!!
Posted on Dec 16, 2008
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
  • 252 Answers
SOURCE: Honeywell thermostat reads ''-AC'' what does this mean?
-AC means no power to thermostat from furnace.
Posted on Apr 12, 2009
  • 252 Answers
SOURCE: my honeywell ct87K thermostat will not turn the heater on
On your thermostat - R is the power in terminal. Y is the cooling out. W is the heating out. (G is fan out). It does not matter which wire goes to R, the other should go to W - if no heat with a call, the thermostat is bad.
Posted on Apr 17, 2009
  • 252 Answers
SOURCE: how do I program my honeywell basic thermostat?
Go to
myhome.honeywell.com
and search for a manual for your model number thermostat on the right hand side of the page.
Posted on Oct 10, 2009
It shows current temp lower than what is programmed. Even when set to temporary, the furnace is not kicking on. All doors shut on furnace, any ideas?
There can be several reasons for this, the thermostat may be working fine but the heater or furnace may cause a lapse in response.
Nov 28, 2015 | Honeywell Programmable Thermostat Heater
My thermostat when prgrammed and set on "auto" mode kicks on heat when temp drops below set temperature. The problem is that after warming up to that temperature...it does not shut the fan off. ...
I have a honeywell TH8320U thermostat and American standard Air handler with heating unit put in. THE thermostat works fine with the ac and follows the programs I have set. However the heat is a different story. The thermo clicks on to follow program but the unit does not run. (auto settings) If I place the thermo in heat and turn it to on I get heat?
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
When i program thermostat to hold it says wait
Wait will come on for 5 minutes.. Wait is the delay built in to protect the compressor.. Just give it time and the system will kick on.. Thank you.,.. I hope this solved your problem. Ask if you need anything else and please rate me...
Sep 02, 2010 | Honeywell Programmable Thermostat Heater
Heater on when not programmed
sounds like a bad t-stat , they have a 5 year warranty on them
Dec 28, 2008 | Honeywell Programmable Thermostat Heater
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
