Question about KitchenAid KUDS03FSSS Dishwasher
Drain line makes loud noise
Just started making noise, purchased in 2006. Drain line vibrates like the line has an air bubble or obstruction in it. Do I need to clear the line of build up? Do I replace part/parts for motor?
    Genius:
  • 1,669 Answers
Yes, by all means, check for obstructions in the drain line. Also check to see that the motor mounts for the drain pump are not damaged. Sometimes the veins in the drain pump get broken off and cause an imbalance in the pump which seems like a clog!
Posted on Jan 01, 2013
markevans
  • 148 Answers
SOURCE: Loud grinding noise when washer is draining
something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
i am confident the issue relates to a pump unit.
good luck
mark
Posted on Dec 28, 2007
  • 2187 Answers
SOURCE: While dishwasher is washing, the motor is making a
You will have to open up the panel to check exactly where the sound comes from. It can come from the motor itself or the moving parts. Some parts are being moved by water and cleaning the insides and the filter sometimes removes the noise.
Posted on Sep 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Kitchenaid Dishwasher has starting making a real loud noise
Hi Andy and welcome to FixYa. I am Kelly. That loud noise your hearing is the motor bearings. If you were to remove the lower kick panel you will prbably find signs of a slow leak of water has been trickling through the motor and you will see a water spot under the motor pump assembly.
You were correct in your assumption that it was bearings. What happens is the motor shaft ceramic seal starts leaking long before the home owner even notices it. Then the water gets into the motor and corrosion starts to build up. As the motor turns the bearing starts to spal as a result of the corrosion and you hear the loud noises.
The only fix for this sadly to say is a complete motor impeller assembly replacement. If your model number is the one associated with this post / question: KUDI01FLSS then there is one more digit after the last "S" that being one of the following numbers 0, 1, 2, 3, 4, 5 or 6.
The motor and impeller for your dishwasher Item 10 or 18 can be found here and is listed at $138.44:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164895&diagram_id=907556#d907556
The seal that has failed is item 23 of the same link. Changing the seal at this point will not stop the noise.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
  • 949 Answers
SOURCE: Dishwasher has starting making a real loud noise
It could be the motor bearings, they can go out if the pump seal starts to leak and moisture gets to the motor bearings. If that is the case you are looking at about $180.00 for the sump and motor (parts only).
It could also be something caught in the sump near the chopper that is creating the noise. Here is a link to some clean out instructions if you are up for trying them.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: MY DISHWASHER IS MAKING A LOUD NOISE AND THE
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jan 06, 2011
After installing the water supply line it makes a huge noise when turned all the way on
Most likely your plumbing system's air chambers have become waterlogged causing the loud noise or water hammer. Turn off the main valve, then open the faucet and allow it to drain thoroughly. Once all the water drains from the chamber, air will fill it again and form a cushion. Hope this helps. Good luck
Mar 12, 2016 | Home
My refrigerator is making bubbling noise how to fix it?
Hello darlene wellman - Generally speaking, it is normal for Frigidaire refrigerators to making a vibrating, snapping, dripping noises however not a bubbling noise. From what you have described it sounds like it could possibly be the drain sucking in air or it could be refrigeration through the evaporator. Honestly, I would suggest contacting a professional to verify it is in fact a normal operation or unit has a defect that needs to be repair.
Oct 09, 2012 | Frigidaire FRS26R4A Side by Side...
Water inside unit, you can hear it when running. I know it's suppose to be normal in high humidity, but the unit was making a loud noise the other night so I had to turn it off. sounded like the fan
The unit is not draining properly. Make sure it is leaning back in the window. If you put a level on the top of the unit, it should be leaning back away from the window about a half bubble. If it still doesn't drain after this, the drain may be stopped up. The drain will either be in the bottom of the unit or on the back. If you try to clean the drain hole be careful not to use anything that will poke a hope in the rear coil. You can use compressed air.
Jul 03, 2011 | GE AEV05LN Air Conditioner
As soon as the washer starts, it makes a noise that isn't normal>>loud
with out further info on the location of the noise.
Does the washer drain. if not check the drain pump and look to see if there is any obstruction.there may have been something that got caught in the drain pump impellar and cause some kind of damage. also check all your shocks and springs. along with the pulley and belt assembly make sure it is all connected properly
Mar 08, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I get repeated F2 messages and when the washer is reset, it makes a low, rumbling noise. I have removed the drain hose and flushed it out (did not see an obstruction). Also have been getting the SUD...
"F02" is a Long Drain error code, which usually means you have an obstruction in the drain pump, drain lines, or the drain pump has failed. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
The "SUD" error can commonly occur with this error due to the detection of air in the drain pump (lack of water flow). If cleaning the drain pump reservoir, and checking all the drain hoses does not correct the problem, you may have a failed drain pump.
Replacement pumps can be purchased on line at searspartsdirect.com, appliancepartspros.com, repairclinic.com or pcappliancerepair.com. All these sites offer competitive pricing so shop all of them for the best price.
If you have any questions about this repair please let me know. I hope this helps you.
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Buzzing - will not spin or drain water
This noise is probably the pump trying to start but will most likely be obstructed.Drain the machine manually by lowering the drain hose into a bucket or bowl and then remove blockage.
Nov 07, 2008 | Frigidaire ATF6000ES Front Load Washer
1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Jul 23, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Loud vibrating/humming noise
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
Apr 21, 2008 | Dishwashers
KitchenAid KUDS03FSSS Dishwasher Logo
85 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
