Question about Canon Pixma MP500 All-In-One InkJet Printer
Fualty photos the photos from my nearly new canon pixma mp500 have white strips down them ,i have cleaned the heads several times but still the same
    Genius:
  • 2,985 Answers
Try he canon technical support team for printers also look in at www.fixyourownprinter.com
Posted on Jun 24, 2007
SOURCE:
Canon Pixma MP 500 Error 5100
You can Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All Best
Jan 15, 2010 | Canon Pixma MP500 All-In-One InkJet...
Photo Printing
How long ago did you replace the cartridges and how long ago did this problem develop?
Thanks,
lee
Jul 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Faulty photos
Here is the link to the support page for the mp500; http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=11995 sorry i cant give you a direct link to the instructions, but if you type "print head cleaning" into the "please enter your question" box (on the support and service tab), then it will take you through the whole procedure, including what to do if the different cleaning procedures do not work. This should resolve your problem, please ask again if you are having trouble still. you can also get the user manual if you prefer to read the instructions in there, available under the "drivers and downloads" tab. Hope this helps :)
Jun 21, 2007 | Canon Pixma MP500 All-In-One InkJet...
Photo quality
With nearly ALL Canon printers, you must use Canon paper for photos. The MP500 isn't really a photo printer like the 600, so that is also a problem. Try using the Canon photo paper. It's a bit pricey, but might be worth it in the long run.
Hope this helps.
Jul 08, 2009 | Canon Pixma MP500 All-In-One InkJet...
Error code 5100
Hi You can Try
Error Code 5100 It is going to need a good clean inside
Solution 1:
Solution 2:
All The Best: Pineworks
Jun 22, 2008 | Canon Pixma MP500 All-In-One InkJet...
MP 500 head needs to be cleaned
i have a fairly new canon printer which sometimes has that problem and i can take out the housing unit that holds the ink cartridges and clean the spots where the tanks meet. hope this helps i don't if this will be the same on the mp500.
May 11, 2008 | Canon Pixma MP500 All-In-One InkJet...
Stripe on back of paper for Canon printer
This is how I finally resolved the issue. Deep cleaning on PGBK head several times and bottom plate cleaning several times. This is done thru maintenance tab.
Apr 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon MP500 printer
We have the same problem. I removed the cartridges, then removed the print head. There was lots of ink gunk on the print head. I cleaned it and the problem disappeared completely for a few days but is now back. I suspect the print head needs to be replaced. Still working on it.
Apr 11, 2008 | Canon Pixma MP500 All-In-One InkJet...
Vertical lines throughout photos
Solution: Clean The Print Head Nozzles (Windows) MP500 / MP800
lean The Print Head Nozzles (Windows) The following contains instructions to check the nozzles for poor print quality and perform cleanings of the print head nozzles as necessary. If print results are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleanings or print head deep cleanings. nozzlecheckflow_en.jpg
Dec 19, 2007 | Canon Pixma MP500 All-In-One InkJet...
Photo Printing
Hi, Most Inkjets have maintenance software installed in the computer itself where the printer is attached. If you would like to try, please click on Start/Printers and Faxes/ A new window will pop up where your Canon Pixma MP500 will be shown. Right click on the Canon icon and left click on the Properties. A new window will pop up. See if there is any Utilities or Maintenance Tab. If none, try clicking on Printing Preferences. Another window will pop up. Normally this is where your Maintenance Option is displayed. Clicking on the Maintenance (sometimes they use Utilities) Tab, a list of maintenance options will be displayed. Pls follow the on screen instructions. They icons represent the action you would want done like head cleaning, alignment, roller cleaning etc. Clicking on the icon initiate the action. Should you still need a copy of the User's Manual, it may be downloaded from www.usa.canon.com Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Jul 31, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
