Question about Samsung LN32A330 32 in. LCD TV
Why is the color not working right on my samsung LN32A330JLD
The color is bad
  • Evan Feb 17, 2013
    I know I'm not being helpful but I have the LN32A300JLD and I have the same issue does anyone know what is wrong and how to fix? its like the contrast is really high but when I change it manually it doesn't do much, color is reallllly off and all manual adjustments are futile.
Samsung led TV un60es8000 dark blotchy area on the upper right of screen. Most noticeable on greys,blues and blacks. The picture attached is the color most responsive to this issue (dark grey). Lighter...
This is caused by one of two things; a bad LED grouping (most common cause) either because the LEDs are bad or the power distributor fuse is blown and the group isn't getting power from the power supply unit. Or two: bad pixel group. But I'd check your backlight power supply for bad connections, blown fuses, or check your led groups for bad leds.
Jan 28, 2015 | Samsung Televison & Video
I have a Samsung CLP 315 color printer that when I print it leaves a gray shadow line from left to right
if it is only one color that cartridge is probly bad. if it were all the colors then it would be somethinfg else. i would try a new black cartridge
Nov 24, 2014 | Samsung CLP-315W Laser Color Printer
Vertical color lines half of screen on right side
probably the 2 ribbon/flex cable(s) aren't connected correctly between the T-CON board and the Scan boards that are connected to the screen/panel!
If not replace T-CON board, and if that does'nt work
the screen/panel is most likely bad!
Nov 15, 2013 | Samsung LN52A850 52 in. LCD HDTV
I have a Samsung CLP-620ND color printer, only 1085 copies printed. After changing the 3 colored toner cartridges, my print out came out bad. Left side of paper around 3
Dear
Open the individual carts from the printer and visually observe the density of toner on the developer roller evenly. Some times the cleaning blade of ITB over come the problem.
Before this try to adjust altitude and cleaning on EPM or smart panel from PC.
Thanks.
Mar 15, 2012 | Samsung CLP620ND Colour Laser Duplex...
Samsung dlp tv makes loud noise when turned on. Previously it was turning itself off.
Bad Color Wheel, Located Right Behind Lamp when you remove Lamp you will see the Color Wheel.
Encompass Parts Distribution 1-800-638-3328
PN# BP96-00250A Price $82.66
Oct 03, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My samsung 5063w turns on and the screen is bright, no noise but the color is "faded" for lack of a better word? what could be the problem?
Reset all ur setting back to factory setting.Still same problems,might be the colors wheel is not woking right anymore.
Mar 26, 2010 | Samsung DLP HL-P5663W 56" TV
TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Oct 06, 2009 | Samsung Televison & Video
Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
Jan 05, 2009 | Samsung CLP 300 Laser Printer
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Samsung HLP 4663
Skippy is right, you should check the color wheel. There are only two moving parts in the set and the color wheel is one of them. If you listen closely to the TV you may hear a high pitched whirr or whine. If so, you've got a bad color wheel motor. If you are mechanically inclined, take the back off and remove the lamp vent. Take off the screws and cables holding the optical block tray and slide the tray out. The lamp points directly at the color wheel. There is a metal heat sink held in place by two silver screws over the compartment infront of the lamp. Using latex gloves, remove those and the whole color wheel assembly will come out. Of course this process isn't as simple as I've stated it but with some common sense you'll be fine. When replacing the wheel pay attention to the model number. Some of these sets use a bearing setup and others an air cushion one. Make sure you order the right part. If you do order the wrong one, not all is lost, you can (with a jumper) modify it to work. Make sure your gloves are clean and re-install the color wheel, and reverse your dismantle. Good luck!
Jul 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung LN32A330 32 in. LCD TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
