Question about Jeep 2004 Wrangler Rubicon
How do i know if my ignition switch in 2004 Jeep Rubicon is broken?
Currently i can turn the switch lights and radio comes on. The battery is good. When i turn the key in the ignition i hear one click coming from the front passenger side of the Jeep.
    Genius:
  • 1,669 Answers
It is probably the starter motor wiring not making good contact (either the thick wire from the battery or the ground wire on the solenoid. Clean up the contact areas and try again! If you still don't get the solenoid to push the starter gear into position, the solenoid needs to be replaced ormaybe just lubricated with CRC or WD 40 spray!
Posted on Jan 01, 2013
  • 33 Answers
Check all the easy stuff 1st-fuses ,relays,make sure you have juice going to small wire going to selinoid when you turn the key(if not its probably the ignition switch) and check your nuetral switch
Posted on Mar 26, 2013
I have a 2008 jeep rubicon that the headlights the indicator lights the wipers and air condition stop working the same time
LIGHT INDICATOR AND WIPER ALL PART OF YOU SWITCH ON THE STEERING COLUMN .BUT FIRST READ YOU MANUAL AND CHECK ALL THE FUSES.INSIDE AND OUTSIDE THE JEEP.NEXT FOLLOW THE GROUND WIRE FROM THE BATTERY AND MAKE SURE THE WIRE IS CLEAN AND TIGHT TO THE BODY.MORE GROUND WIRE WILL FIND UNDER THE DASH BOARD CLOSE TO THE DOOR HINCH.
GOOD LUCK
Mar 27, 2014 | 2008 Jeep Wrangler Rubicon
Jeep 2007 Wrangler Unlimited X 4x4 4 Doors
Sounds like a short in the electrical system. Maybe even just a loose ground wire. On the other hand...It could just as easily be a bad ECM (BRAIN)! Warranty still in tact? I hope so. Diagnostic at a certified Jeep shop... Good Luck!
Apr 09, 2010 | 2007 Jeep Wrangler Unlimited Rubicon 2...
Good battery, turn key doesnt do anything. Jeep
If its a stick you may have a problem with the clutch safety switch. They don't want you starting the jeep without the clutch in. If the safety switch has failed it may think the clutch is still released. Also make sure the battery terminals are clean. If your lights don't shine bright you need to start looking for a connection issue to the battery if you know the battery is good.
Feb 02, 2010 | 2006 Jeep Wrangler
2004 jeep wrangler unlimited wont start ,4.0l auto , new starter and battery , when turn the key lights come on fuel pump lights in dash.
Nuetral safty switch, Starter solenoid.
Do you have antitheft?
The ground for the starter relay may be computer controlled. Lee
Oct 04, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
2007 Rubicon radio will not come on
Check the IOD fuse in the engine back it is a double 10 amp fuse with a pull up tab. If that is good you need a radio should still be under warenty.
Jul 13, 2009 | 2007 Jeep Wrangler Unlimited Rubicon 2...
I have a 2005 jeep rubicon my interior light wont turn off with the swich on the steering coulmn. i have to remove the fuse to turn it off
replace the electronic device in the steering column. IC inside the device has broken which related to light switch.
Jun 21, 2009 | Jeep Wrangler Cars & Trucks
2004 Jeep Rubicon lockers dont work when warm. in
sounds to me that you may be having air pump issues, or your having rocker switch issues, I would lean toward the pumps though, just replaced mine in my 03 rubicon and problem solved, also insect the vacuum hoses going to each locker, make sure they dont have any holes/ cracks
Apr 26, 2009 | 2004 Jeep Wrangler
Engine will not crank at all...still getting electric power
have you checked the battery? try jumping it. most autoparts stores will test them for free
Nov 30, 2008 | 2003 Jeep Liberty
Jeep 2004 Wrangler Rubicon Logo
81 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
