Question about Intel Motherboard
Sound p5kpal-amse
  • Intel Master
  • 5,660 Answers
Asus Support > P5KPAL-AMSE > Main Support page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/
Click on the Download tab.
(Overview / Specification / Download / etc)
To the right of the Select OS box; click on the blue Down Arrow.
Click on the Operating System you are using.
Since you didn't state what O/S you are using, I'm going to use WinXP as an example.
Click on the + sign to the left of - Audio (5), in blue.
FIVE audio drivers are listed.
ALL are for a VIA audio chipset.
FOUR are for WinXP 32-bit, or 64-bit.
ONE may be just for WinXP 32-bit.
Which one to choose?
Suggest choosing the newest version - Version 6.0.1.7600
(2009.11.13 update)
Click on the blue Global.
[If this doesn't work? Audio driver may be too new.
All you have to do is go into Add/Remove Programs, and remove it.
Then suggest go back to Asus Support again, and download AND install the oldest version - Version 6.0.1.1430 ]
After you click on the blue Global, a small window will come up -
Opening VIA_Audio_V6017600.zip
Make SURE there is a Green dot in the small circle, to the left of - Save File.
If not; left-click in the empty circle to the left of - Save File.
Now go below in the window, and click on - OK.
Another small window will come up. Allow the file to Fully download, then DOUBLE-click right on the file name.
In the next small window go to the far left, and click on - Extract all files.
At the bottom of the next 3 small windows click on -
Next, Next, and Finish.
When finished if not asked to do so, restart your computer.
If the Sound icon is not in your system tray, at the bottom of your Windows desktop screen, post back in a Comment.
What happens? Windoze takes a 'holiday' sometimes.
Looses the address to the driver file.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 01, 2013
No Fuel or spark
problema de encendido de carro pontiac gran amse hace encender pero no enciende y aparece alarme de segurity en el tablero
Oct 17, 2012 | 2006 Mitsubishi Galant ES
Engine backfires
problema de encendido carro pontiac gran amse 2002 aparece alrma de segurity de encendido
Oct 17, 2012 | Cars & Trucks
I have a p5kpl-amse moth,board . the BIOS is faulty !! how do Iupdate it ?? I have to push reboot several times to get my computer to start.
http://majorgeeks.com/BIOS_Finder_d237.html
Searches for newer BIOS for your board
Assists in flash upgrading your system BIOS to a later version. BIOS Finder determines your system BIOS and when run, cross references Flash upgrade BIOS files you have downloaded from the manufactures web site. If a later version match is found this BIOS is placed into a directory for you to upgrade to. Great for Y2K issues and beyond, overcome that greater than 8.4 Gig limitation with your BIOS, resolve those video card glitches. Download, run and your on your way to a later BIOS version! (Award only).
This older version will only work on motherboards with 128K bios files. Most boards these days are supplied with 256 or 512K firmware.
hope this helps
Apr 21, 2011 | ASUS Computers & Internet
Ringer is marked as off on my blackberry bold 9700 and i have no sound
Hi,Sound profiles define how your BlackBerry device alerts you of phone calls, messages, reminders, and browser content.
Your device has a Normal sound profile and six other preloaded sound profiles: Loud, Medium, Vibrate Only, Silent, Phone Calls Only, and All Alerts Off.
By default, some of the settings in the preloaded sound profiles are based on the settings in the Normal sound profile. For example, when you change the ring tone in the Normal sound profile, the ring tone in the Loud, Medium, and Phone Calls Only sound profiles is automatically updated. If you do not want specific settings for a preloaded sound profile to update automatically when you change the corresponding setting in the Normal profile, you can manually change the settings in that preloaded sound profile.
You can create custom sound profiles. When you assign a custom ring tone to a contact, the ring tone is always active and does not change when you switch sound profiles unless you switch to the All Alerts Off sound profile. Call and message notifications for your contacts might be audible even if you switch your sound profile to Silent or Vibrate Only.
You can change, rename, and delete most preloaded sound profiles. You cannot delete the Vibrate Only sound profile and you cannot change, rename or delete the All Alerts Off sound profiles. You can change the Normal sound profile, but you cannot rename or delete it because some of the settings in the other preloaded sound profiles are based on the settings in the Normal sound profile.
Sound profiles define how your BlackBerry® device alerts you of phone calls, messages, reminders, and browser content.
Change a sound profile
If you change a setting in a preloaded sound profile that is based on the Normal sound profile, that change will override the corresponding Normal sound profile setting in the preloaded sound profile.
1. On the Home screen, click the Sounds icon.
2. Perform one of the following actions:
* To change the active sound profile, click Set Ring Tones/Alerts.
* To change a custom or preloaded sound profile, click Edit Profiles. Click a profile.
3. Click the application or item that you want to change.
4. Change the notification information.
5. Press the Menu key.
6. Click Save.
7. Press the Menu key.
8. Click Save.
Hope that helped...
Feb 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
The SH-S223L/RSBS samsung dvd-rom is supposed to read and write dvd discs. However, the device wasn't able to read it. Prior to installation of a USB type modem for internet connection (HUAWEI), the dvd...
Just click on the link http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
and also click on NOW RUN from right side box. It will automatically give youthe message, well or bad.
If the problem with the lens, you should try cleaningthe lens,with disk cleaner, it's already gone bad and there is no harm to take a risk to open ordisassemble the dvd/cd rw,click on the bellow link http://www.youtube.com/watch?v=WaiTJYHQCCg
  1. When running your pc, open the drawer.>
  2. clean the optical lance
  3. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
  4. now you can fit to your pc
If it does the same problemplease change the cd/dvd rw because the lance has defected. After doing all the step please install a new pata/sata cable .
Or you can restore your sysstem http://vlaurie.com/computers2/Articles/windows7-system-restore.htm
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 16, 2011 | Samsung 22x DVD-W H/H LightScribe H/H SATA...
Error ID = 0xC00D11BA, Condition ID = 0x00000000
Your sound card might be in use by another application.
0xC00D11BA: Cannot play the file
Windows Media Player cannot play the file because there is a problem with
your sound device, such as a sound card or sound controller. You may
encounter this error message for one of the following reasons:
Your sound device is in use by another program. Quit other programs that may
be using your sound device, and then try to play the file again.
Your sound device is not functioning properly. To troubleshoot the problem,
see the Sound Troubleshooter in Windows Help or refer to your sound device's
documentation.
You do not have a sound device installed on your computer. Install a sound
Apr 10, 2010 | Microsoft Windows XP Professional for PC
My sound card is not working
look for the model number on the card and goto the manufactures website and download the driver
Aug 21, 2009 | Compaq Creative Sound Blaster PCI 64 Sound...
Sound Quality Comparision
Slight difference.....The sound quality difference is observed.
You can find out the difference.In every motherboard on board sound is not so good.But in sound cards it is disigned specifically for sound.
if it helps
Pls RATE ME
Jun 25, 2009 | Intel D865GBF Motherboard
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Jul 04, 2008 | E-Machines eMachines Desktop PC
LG WM1812CW noise
Other than seperating the drums you could try to remove the heater element which will allow you limited access to the cavity between the drums. Shine a torch in there and rotate the inner drum slowly untill the offending piece comes into view. Remove with a long tweesers or hook.
Oct 27, 2007 | LG WM1812C Front Load Washer
Intel Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
