Question about Ignition System for Mitsubishi Mighty Max
Univeral ignition switch faulty or what
Put a universal ignition switch in 1991 mitsubishi mighty max 2.4 manual long story short clicking when starting now no power at all
  • Mitsubishi Master
  • 1,631 Answers
There are 2 sets of 3 "Fusible Links" on the drivers side under the hood.
Right at the positive side of the battery is a box of 3 larger fuses, the middle one could be bad, but check them all.
and then further back near the firewall, is a block with 3 wires. Those are actually fusible links, which can burn out as well. Check with a test light on each side of the wire: fender side is hot, goes thru the link to the engine side sending power to appropriate places, if power on engine side, bad link. You can buy a roll of fusible link at most parts stores, for under $5.00
  • There is also a relay, that runs ignition, fuel pump, & ???
    • It is located in the cab, passenger side behind the floor kick panel just inside behind the bottom door hinge.
good luck
Posted on May 08, 2015
    Champion:
    Scholar:
  • 227 Answers
Can you bypass the switch and get it to start?? of so it's bad.
Posted on Nov 01, 2013
What is the torque for installing the crankshaft for the 2.4 mitymax motor?
Mitsubishi Mighty Max crankshaft bolt Questions & Answers ...
www.fixya.com > ... > crankshaft bolt > Cars & Trucks > Mitsubishi
Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
Oct 02, 2015 | Cars & Trucks
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
Aug 17, 2011 | 1993 Mitsubishi Mighty Max
1991 mitsubishi mighty max want start in cold weather but will when its warm outside what could be the problem?
if this is carb motor than it needs a manual choke that mounts on inside of lower dash, the kind you see on lawn mowers,,,push and pull.
Mar 11, 2011 | 1991 Mitsubishi Mighty Max
How to reset maintenance required light for 1991 mitsubishi mighty max
there is a small switch behind one of the switch blank off plates to the right of the steering column. It is a very small switch about 6" deep into the dash, hard to find easy to reset.
Nov 12, 2010 | 1990 Mitsubishi Mighty Max
I have a 1991 mitsibishi mighty max and it blows thick white smoke when I start it, why does it do that. It runs good though.
you have water/coolant entering the combustion chamber. either the head is cracked or you have blown a head gasket.
Oct 09, 2010 | 1991 Mitsubishi Mighty Max
Put in distributor for 1991 mitsubishi mighty max
Please confirm which engine your truck has; 3.0 V6?
Thanks,
Tom
Feb 28, 2010 | 1991 Mitsubishi Mighty Max
Per my Chilton's manual tehe bolts should be (cold engine) 65 to 72 FT. Pnds., the cam shaft bearing bolts should be 8x25 = 15 - 19 Ft pnds and the 8x65 should be 14 - 15 Ft Pnds.
The sequence is as follows for the (10 ) head bolts:
7 - 5 - 2 - 4 - 10
9 - 3 - 1 - 6 - 8
I hope this may help,
Tom
Oct 12, 2009 | 1991 Mitsubishi Mighty Max
1991 Mitsubishi Might Max Timing Belt
timing chain when you get a variance in timing easy to see with a timing light haynes manual should be sufficient
Jul 21, 2009 | 1991 Mitsubishi Mighty Max
1991 mighty max
If it is 4X4 and you re not going far. Put the transfer case in neutral. If it is 2X4 standard transmission, put it in neutral. If it is an automatic transmission you need to remove the driveline.
Jul 10, 2008 | 1991 Mitsubishi Mighty Max
Ignition System for Mitsubishi Mighty Max Logo
79 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
